Those are awesome gordie thanks for sharing. Is that your own pattern?
HI Todd..the horses are Steve Goods.
Also the basic shape of address signs is on Steve Goods site also.
I give it a different twist by the way I letter it.
Letters are raised small amount 1/8 the inch approx.
Did you raise the hummingbirds as will?
Yes the Humming birds are raised up also.It is just
A slight raise.so it will be easy to touch up paint when needed.
The one I am cutting now,Is a bit higher as I went 6 degrees.
I should try and put some pictures on how it is done.It is surprisingly quite easy anday results are nice.
Really nice work, I especially like the horses and wanted to make them, but cant find them on steve goods site, thx RJ
Go to Steve's site and search for wild running horses and it will come up.
You can also just search for horses in all category and you will get it.
Spring is here and I guess people want to get outside and do some
decorating and such.
Another address sign for today and three more to do for next week.
Also made this Steve good horses,while waiting for spar to dry.
scrap piece of birch,stained cherry.
Well done Mr. Gordie,Take a break now that's  enough for one day!
Gordie, I really like the look of the raised numbers and hummingbird. Sure can't see any entry holes. What blade are you using?
Thanks Dave I am using a #2...Bosch blades I get here at hardware store.
If you use a bigger blade,you will have to adjust the degree you cut at.
Practice with it and remember to cut counter clockwise for a raised letter and clockwise for a recess.
Edited by Gordster
That would be great Gordie I may even give it a go if I see how it is done  :)  :D Frank
