I saw where someone cut this traditionally, and thought I would try it on a coin.
I've had several requests to put up a video of some cutting, so here is a link to some pretty raw footage.
https://youtu.be/A1jp7eau9Ww
I'll do a more instructional video at some point and polish it up a bit, but this should give you a feel for how this goes.  I had a drill bit break off in the coin, in a tight place where there wasn't enough room for another entry hole, so there is a portion in the middle of the video where I'm working through that issue.
Edited by hotshot
I'll do a more instructional video at some point and polish it up a bit, but this should give you a feel for how this goes.  I had a drill bit break off in the coin, in a tight place where there wasn't enough room for another entry hole, so there is a portion in the middle if the video where I'm working through that issue.
I tryed 3 ways to watch and could not?
Beautiful work Randy....You will have to go to your
utube settings and select public as now it is in private.
I even went to my utube account and pasted your link
and it said no results found
Edited by Gordster
Excellently Done Randy.  Thanks for sharing this work of art with us.  How many blades do you generally go thru when making something like this?
DW
Probably about 8 or so
Hey, if anyone watches the video, please like it on YouTube.  Not a lot of people do this type of cutting on the scroll saw and I'm trying to evangelize the heck out of coin cutting with the scroll saw, so hopefully a few likes will give these kinds of projects more visibility.
Plus, hopefully I'll direct a few viewers back to this community.
Edited by hotshot
