Most of my posts are under Other Woodworks. But I do some scroll work so here's an example.
This little project was meant to use cut-offs from a storage unit project that needed a home. I've always been a fan of the Wright's work and in browsing the internet I came across a image that looked like this. I copied it and used it for a pattern. Personal use only. As you can see I glued 6 pieces of stock (.625" cherry) together so I had enough width to make a trivet (6.125" square). It has a couple of spots where either the grain is working against me or the glue is giving up?
Scrolling straight lines and all right angle corners was difficult for a amateur scoller like me.
Problems aside I'm still pleased with the look. This is my first post since the big change-over. I hope the pics show up? No preview, I'll miss that.
C & C welcome.
Edited by oldhudson
C & C welcome.
Things go wrong when we least expect it .Beautiful cutting
Nice work Berry. Straight lines are the hardest to do. You didn't say what size blade you used but I would use a larger blade such as a #5 or larger.
An old wise man (Mike, of Flying Dutchman fame) used to say: cutting a straight line is like driving a straight road, you have to move the wheel left and right to go straight. That comes to mind every time I cut straight lines.
