hotshot Posted April 22, 2017 Report Posted April 22, 2017 Ok, I'm sure some of you were hoping this was in wood . . . in time, I'll get back to wood, but I just need to get metal out of my system first. In any case, you have to admit, you have probably never seen this done with coins before :-)The gold/bronze inlayed coin is a Greek 100 Drachma, the copper is a Provident Mint coin. Blade was 2/0, angle for inlay was just under 8 degrees. You can't really tell it in the picture, but I lucked out and the inlay is perfectly flush and tight. I'll probably drill a hole in the top for a chain or something.-----Randy munzieb, lawson56, MTCowpoke22 and 3 others 6 Quote
DWSUDEKUM Posted April 22, 2017 Report Posted April 22, 2017 Dang Randy .. admit it you have a micro cnc machine in the shop hidden away. What a wonderful cutting my friend. Thanks for sharing this amazing work of art with us. DW Quote
wombatie Posted April 22, 2017 Report Posted April 22, 2017 Perfect. Amazing cutting skills and you are right I have never seen this before. Well done. Marg Quote
Fab4 Posted April 22, 2017 Report Posted April 22, 2017 HI Randy: Here I was thinking that you couldn't get any crazier with your coins Now this - This is definitely "insaner" but always in a good way Thanks for showing/inspiring us Fab4 Quote
Scrolling Steve Posted April 22, 2017 Report Posted April 22, 2017 That is pretty stinking neat !......Nice cutting of the coin, Randy ! Quote
Dave Monk Posted April 22, 2017 Report Posted April 22, 2017 Randy, I sure hope you do not get that coin cutting out of your system. I love seeing your work. That is crazy good. Quote
Scrappile Posted April 22, 2017 Report Posted April 22, 2017 That is some very fine cutting. "Fine" as in delicate and "fine" as in awesome looking. Go back to wood if you want, but do not quite the metal cutting. Love seeing it. Quote
dgman Posted April 22, 2017 Report Posted April 22, 2017 You've outdone yourself Randy! I know you said the inlay is flush and tight, but did you have to glue it in or solder it? Quote
hotshot Posted April 22, 2017 Author Report Posted April 22, 2017 (edited) 4 hours ago, dgman said: You've outdone yourself Randy! I know you said the inlay is flush and tight, but did you have to glue it in or solder it? Used CA glue to make sure it doesn't come out. Over time, I'm not sure if it will hold, I'll have to see. A real Jeweler probably would have silver soldered it. Edited April 22, 2017 by hotshot Quote
GPscroller Posted April 22, 2017 Report Posted April 22, 2017 Awesome work!! Always look forward to see what you cut next and am amazed every time. Thanks for the pic. Jeff Quote
Gordster Posted April 22, 2017 Report Posted April 22, 2017 Randy,that is Amazing. ..to get that to fit with 7 or 8 degrees must have been some feeling for you. Quote
spirithorse Posted April 22, 2017 Report Posted April 22, 2017 Great work, Randy, Thanks for sharing and God Bless! Spirithorse Quote
hotshot Posted April 23, 2017 Author Report Posted April 23, 2017 2 hours ago, Gordster said: Randy,that is Amazing. ..to get that to fit with 7 or 8 degrees must have been some feeling for you. I didn't have much scrap in that thickness to test on, but I found a big enough piece to cut a few really small test circles, and when I thought I was close, I tweaked the angle up just a little to be tight. I was relieved it worked. Gordster 1 Quote
newfie Posted April 23, 2017 Report Posted April 23, 2017 Nice cutting Randy thanks for sharing Quote
