Drum Sander
I have been thinking about building a drum sander for quite awhile and recently built one.  It is powered by my Shopsmith Mark 5 which I purchased many years ago for $125.  Mine is loosely based upon the StumpyNubs version and the one built by Shipwright on the Lumberjocks forum.
The drum is built with a 5/8" steel rod and 4" plywood disks and is about 18" long.  The disks were glued together and then turned using the Shopsmith as a lathe.  The end of the shaft connects with the Shopsmith and the speed can be varied. The ends of the shafts are also supported with sealed bearings.  The top is based upon the StumpyNubs design with the 2" wide aluminum bar set into the baltic birch top.
The sand paper is hook and loop.  The Velcro on the drum was ordered on Amazon and is the industrial strength velcro and works well.
This was not a real easy build.  Getting the drum the same diameter along the length and running true took some time.  The top also took a lot of time and getting it aligned with the drum was also time consuming.
I added a PVC pipe running through the sander to collect the dust and it works pretty well but I am working to improve it.
I have been using it to clean up some boards for projects and also for making some boxes with finger joints.  I am pleased with it.
It is also possible to add a thickness sander to this design by going under the drum.  I have not done this yet and will have to decide if I want this added feature.
Edited by Sycamore67
spelling
Larry that is nice. How do you keep the same pressure one board so it will be flat after running it through?
You did it up very nice.i'm sure you smile every time you use it now.What else do you have on your bucket list as far as shop gizmos?
