Rockytime Posted August 16, 2019 Report Posted August 16, 2019 OOOOOPS, I hit quote rather than edit. DUH OCtoolguy 1 Quote
ImaginationUnincorporated Posted August 17, 2019 Report Posted August 17, 2019 I was just thinking about the rare earth magnets for the lower holder flipping out of place problem. For those unfamiliar with rare earth magnets, this five foot tall waking stick should give a hint of their power. This on is on my table saw with nothing but the magnet on the bottom holding it up. danny, Rockytime and OCtoolguy 2 1 Quote
Rockytime Posted August 17, 2019 Report Posted August 17, 2019 These magnets are epoxied in. They go nowhere. However, I just tilt down for instant release. I use them in many places. OCtoolguy 1 Quote
Popular Post Jim Finn Posted August 18, 2019 Popular Post Report Posted August 18, 2019 Here is another modification to my Hegner saws I made. Helps to center the blade in the clamp. Just pop riveted in place. VernLeonard, jbrowning, danny and 7 others 7 3 Quote
Rockytime Posted August 18, 2019 Report Posted August 18, 2019 Thanks. That is a clever idea I WILL STEAL! Perhaps BORROW is a better word. danny, OCtoolguy and Jim Finn 2 1 Quote
Sycamore67 Posted August 18, 2019 Report Posted August 18, 2019 Jim Finn that is a great idea. Jim Finn and OCtoolguy 2 Quote
stoney Posted August 18, 2019 Author Report Posted August 18, 2019 15 hours ago, Jim Finn said: Here is another modification to my Hegner saws I made. Helps to center the blade in the clamp. Just pop riveted in place. Hegner should incorporate your design into their blade clamp jig Jim. You and I could set them people straight on a few things if only we could speak German. OCtoolguy and Jim Finn 1 1 Quote
Scrappile Posted August 18, 2019 Report Posted August 18, 2019 Or you two could make a saw like the Hegner with your ideas and add another scroll saw to those available. While you are producing these saws, add a bigger table to it. OCtoolguy, danny, Jim Finn and 1 other 3 1 Quote
Rockytime Posted August 19, 2019 Report Posted August 19, 2019 On 8/17/2019 at 7:07 PM, Jim Finn said: Here is another modification to my Hegner saws I made. Helps to center the blade in the clamp. Just pop riveted in place. Can I presume you drilled through holes? Would not ever have thought of pop rivets. Good thinking out of the box. Jim Finn and OCtoolguy 2 Quote
Jim Finn Posted August 19, 2019 Report Posted August 19, 2019 I drilled the holes for the rivets about 1/4" deep, then installed the aluminium rivets. OCtoolguy and Rockytime 1 1 Quote
Rockytime Posted August 24, 2019 Report Posted August 24, 2019 I just made the same this evening. The pop rivets are genius! I have one more to make. OCtoolguy, danny and Dave Monk 3 Quote
JimErn Posted August 24, 2019 Report Posted August 24, 2019 I understand the mod for centering the blade on the hegner But what is the inset for in your pic that looks like a saw blade? or is that just to remind you what to use that inset area for? OCtoolguy 1 Quote
Jim Finn Posted August 24, 2019 Report Posted August 24, 2019 Hegner puts the "saw teeth" in there clamp holder to show you which way the teeth should face, I guess. I have found that I scratched my arm on this modification so I rounded off the corners a bit. OCtoolguy 1 Quote
JimErn Posted August 24, 2019 Report Posted August 24, 2019 1 hour ago, Jim Finn said: Hegner puts the "saw teeth" in there clamp holder to show you which way the teeth should face, I guess. I have found that I scratched my arm on this modification so I rounded off the corners a bit. I thought that might be it, but then I thought why make it a cut out when an engraved outline would work fine. thanks Jim Finn and OCtoolguy 1 1 Quote
Sycamore67 Posted August 24, 2019 Report Posted August 24, 2019 I think everything on a Hegner is made to last forever and the cut out will never wear off. Hegner saws seem to last a long time with no problems. OCtoolguy, danny and Jim Finn 3 Quote
Scrappile Posted August 24, 2019 Report Posted August 24, 2019 Does that modification work well for all sizes of blades? Jim Finn and OCtoolguy 2 Quote
Rockytime Posted August 24, 2019 Report Posted August 24, 2019 Yep, it sure does. Jim Finn and OCtoolguy 2 Quote
stoney Posted August 26, 2019 Author Report Posted August 26, 2019 (edited) Another twist on Jim Finn's modification to the Hegner blade clamp jig. My thought was the V will accommodate any size blade. Edited August 26, 2019 by stoney danny, Jim Finn, Dave Monk and 3 others 6 Quote
Rockytime Posted August 27, 2019 Report Posted August 27, 2019 That mod looks great Al. This site is full of innovative people ! OCtoolguy, stoney, Jim Finn and 1 other 3 1 Quote
Rockytime Posted August 29, 2019 Report Posted August 29, 2019 Just cut the boss off my 14" Hegner. Gave another couple of inches for bottom feeding. If I don't need it I get rid of it. OCtoolguy and Jim Finn 1 1 Quote
OCtoolguy Posted August 30, 2019 Report Posted August 30, 2019 1 hour ago, Rockytime said: Just cut the boss off my 14" Hegner. Gave another couple of inches for bottom feeding. If I don't need it I get rid of it. It does make a person wonder why they put it there in the beginning. And never changed it. Jim Finn 1 Quote
stoney Posted August 30, 2019 Author Report Posted August 30, 2019 I don't Know about the 14 inch Hegner but on the 18 and 22 inch machines it's because of the hold down rod. If you look at the pictures of my machine you will notice that I had to raise the arm and lengthen the rod for the hold down in order to accommodate the extra clearance. OCtoolguy 1 Quote
OCtoolguy Posted August 30, 2019 Report Posted August 30, 2019 16 minutes ago, stoney said: I don't Know about the 14 inch Hegner but on the 18 and 22 inch machines it's because of the hold down rod. If you look at the pictures of my machine you will notice that I had to raise the arm and lengthen the rod for the hold down in order to accommodate the extra clearance. Who uses a hold down anyway? Quote
stoney Posted August 30, 2019 Author Report Posted August 30, 2019 4 minutes ago, octoolguy said: Who uses a hold down anyway? I do Ray otherwise I wouldn't have bothered. JimErn and OCtoolguy 1 1 Quote
