Seeking wisdom!  I've recently started trying some inlay work and have found that filling the drill-holes are a challenge to say the least.  I've tried making a sawdust paste with wood glue and even tried using super glue on top of the sawdust (which seems to work best).  The issue I'm facing is that if I laminate 2 boards together to do the inlay work, my drill holes are harder to fill.  If I cut each piece separately, then the drill holes are removed from the equation, but the required precision of the cuts are increased ten-fold.  The smallest drill bit I can find around here is 1/16th.  Is there a smaller bit size I should be using?  For those who do inlay work, is it better to work on each piece separately or laminated together? Thanks in advance!  Attached is pic of my first inlay placed on a band saw clock I made a few weeks ago.  I cut the maple inlay pieces out first, and then cut the red cedar out.
I'm don inlay expert but I do know you can find small drill bits on the internet at about any of the sites that sell scroll saw blades. i.e. Wooden Teddy bear, Mike's Workshop...  There are two tutorials on this site about inlay work that were posted in the last few weeks.
Nice looking clock
All my current blades are flying dutchman from Mike's workshop. He lists the smallest drill size for each blade and I made a chart to keep by the saw. The #5 for most types of FD blades fits in a #60 hole. The #1 size 65-68, and the puzzle blades will fit in a #71. I'm pretty sure that the other types (Olsen, ??) also list the size of the drill bit to use.
Mike's workshop also sells 6-packs of choose-your-size drill bits for $5, and I'm sure the other sellers do to.
Or if you want a set of many sizes cheap, I just bought two sets of #60-80 drill bits at sciplus.com for 7.95 each and a real cheap (3.95) set of 15 metric bits 1-2mm for places where any old hole will do.
Not sure if you have a Menards store nearby but my local Menards has the numbered drill bits. I believe they come in a 2 pack if I remember correctly.. I typically buy them from Mikes Workshop but from time to time I loose or break them.. then forget to order some more. Nice to have them locally if I am in desperate need..
Kevin
I definitely stack cut my inlays. I use 1/32" drill bit that buy on e bay. I am using Pegas  Modified Geometries Blades. I have tried every brand but it is my favorite. Size #1 on my inlays. Just about everything else I use #5.  My go to filler is Famo Wood. It comes in several wood colors. There are many here that have much more talent and expertise than I when it comes to scrolling and inlays...........just thought I would share my two cents worth.
I do LOTS of inlays.  Over 2000 to date.  Double stack the woods, drill the starter holes at an angle steeper than the angle the scroll saw table is tilted to. I use 3/8" woods and I tilt my scroll saw table about 2° and dill the starter hole at about 6° using a 1/16" bit in a rotary tool (like a Dremel)  I make a filler  by mixing white glue and sanding powder (sawdust is too coarse) to the consistency of mayonnaise.  I apply this paste using a credit card as a squeegee and sand well after it dries (in about ten minutes)Couple.thumb.jpg.d63262c1f9ac86ceef81ae90f8fec5c4.jpg592395bd2074a_Rotarytooljig.thumb.jpg.6dd2e3d0afac6f948b2151d47fa3b450.jpg
When doing inlay I drill my starter hole at the same angle as my scroll saw table. Approximately 4 degrees to the left (using ⅛" woods).  Drilling almost inside cutting line will eliminate the need of using any filler if your inlay piece is cut accordingly. Always do your cutting counter clock wise. I use micro drill bits (size 60 - 80) that come in a 20 pack available from Amazon.
Edited by Ron Johnson
For drill bits I buy them here. They don't mined small orders.
https://drillsandcutters.com/
i got my tiny drills from mike 's workshop and the chuck to hold them from Lowes for $28.00
Edited by amazingkevin
hit the wrong key ,a 4 instead of a $
On 5/23/2017 at 11:06 PM, heppnerguy said:
Jim Finn and Ron Johnson are both super craftsmen and you can always rely on any in put you can get from them.  Jim Finn posted a detailed article here in The Village that will step anyone through the process of inlay. Jim has probably done more inlay than everyone else here, combined..
Dick
heppnerguy
I can't seem to find the article from Mr. Finn you mentioned in your post.  Can you post a link in the reply? Much obliged!
Gorgeous inlay! Thanks for the advice...now back to the shop :)
