blights69 Posted May 26, 2017 Report Posted May 26, 2017 Had my first go at a puzzle after seeing Paul and Scott doing some thought I would give it a go so purchased some patterns from Iggy (Scott) thanks for the tips on ordering paul and the tips from Iggy on what is needed. I gave this a go found the lines a task lol but for a first attempt not too shabby I think apart from the drill hole by the bloody ear that I have learn`t my lesson from to put me glasses on when I change the drill bit, Open to comments,tips etc as always, I used a #3 Olsen (more than one lol) gotta get used to a set blade for these I think the veining was the one that caught me the most what do most of you use I shall try that on the next one I used a #3/0 for the lines and I felt it struggled or could of been me taking ages to do them lol or do you do the lines with a spiral I just thought lol MTCowpoke22, Dan, Lee Huntley and 3 others 6 Quote
Iguanadon Posted May 26, 2017 Report Posted May 26, 2017 (edited) Very nice Frank. Yep, you started with one that has a lot of feature lines (cuts). Ooops, and I sent you the sitting Pug instead of the standing one... check your email, I just sent you the one you asked for. Sorry for the error. I use #3 Olson Mach Speed blade for everything. Keep sharing as you cut them, I enjoy seeing them! Edited May 26, 2017 by Iguanadon blights69 1 Quote
blights69 Posted May 26, 2017 Author Report Posted May 26, 2017 4 minutes ago, Iguanadon said: Very nice Frank. Yep, you started with one that has a lot of feature lines (cuts). Ooops, and I sent you the sitting Pug instead of the standing one... check your email, I just sent you the one you asked for. Sorry for the error. I use #3 Olson Mach Speed blade for everything. Keep sharing as you cut them, I enjoy seeing them! Thanks Iggy for the pattern and also the blade tip I shall order some if i can find them in uk if not I will use Teddybear again Quote
Scrappile Posted May 26, 2017 Report Posted May 26, 2017 Nice cutting, Frank. I did mine in 1/2" material. tried several blades I would normally use and ended up doing most with a #3 Pegas Modified Geometry. Use same blade for the veining. blights69 1 Quote
Aggie Posted May 26, 2017 Report Posted May 26, 2017 Nice cutting job you did there . blights69 1 Quote
blights69 Posted May 26, 2017 Author Report Posted May 26, 2017 12 minutes ago, Scrappile said: Nice cutting, Frank. I did mine in 1/2" material. tried several blades I would normally use and ended up doing most with a #3 Pegas Modified Geometry. Use same blade for the veining. Thanks Paul I did think about the Pegas modified blade now you have said you used them I will try them they are easy to get hold of here olsen are more tricky Quote
DWSUDEKUM Posted May 26, 2017 Report Posted May 26, 2017 Nicely done Frank. That came out great. Thanks for sharing this with us. DW blights69 1 Quote
GPscroller Posted May 27, 2017 Report Posted May 27, 2017 Always liked that Pug pattern because of all the character lines. Well done Frank. Jeff blights69 1 Quote
newfie Posted May 27, 2017 Report Posted May 27, 2017 Nice cutting Frank thanks for sharing blights69 1 Quote
wombatie Posted May 27, 2017 Report Posted May 27, 2017 You may have picked the hardest to do first, but all in all you did a great job. Well done Frank. Marg blights69 1 Quote
meflick Posted May 27, 2017 Report Posted May 27, 2017 Excellent piece of art you have crafted. Do you always start with the harder ones first? Thanks for sharing. blights69 1 Quote
blights69 Posted May 27, 2017 Author Report Posted May 27, 2017 2 hours ago, meflick said: Excellent piece of art you have crafted. Do you always start with the harder ones first? Thanks for sharing. Yea Mel that is me all over always pick the toughest first then the rest should be easy in theory lol meflick 1 Quote
smitty0312 Posted May 27, 2017 Report Posted May 27, 2017 Looks like you got it Frank.......A+++ blights69 1 Quote
amazingkevin Posted May 28, 2017 Report Posted May 28, 2017 On 5/26/2017 at 1:50 PM, blights69 said: Had my first go at a puzzle after seeing Paul and Scott doing some thought I would give it a go so purchased some patterns from Iggy (Scott) thanks for the tips on ordering paul and the tips from Iggy on what is needed. I gave this a go found the lines a task lol but for a first attempt not too shabby I think apart from the drill hole by the bloody ear that I have learn`t my lesson from to put me glasses on when I change the drill bit, Open to comments,tips etc as always, I used a #3 Olsen (more than one lol) gotta get used to a set blade for these I think the veining was the one that caught me the most what do most of you use I shall try that on the next one I used a #3/0 for the lines and I felt it struggled or could of been me taking ages to do them lol or do you do the lines with a spiral I just thought lol Handsome job cutting this heart breaker! blights69 1 Quote
