I have a couple of wedding coming up - 1 next weekend & one in July for family members & close friends. I decided to cut a piece for the Weddings. Thank goodness for stack cutting or i would still be cutting the 1st one. 1st one complete and the 2nd one all i have is the frame itself.
Pattern came from Cherry Tree and is a Wildwood Design called Home Rules.
Woods are 1/4" Cherry & maple and 1/8" Baltic Birch
Fantastic lettering Brian. It looks fabulous.  Both couples will love it.. :thumbs:;)  If you stack cut the words why didn't you stack cut the frame?
Marg
Expand
I've never seen something so detailed as this ,top job!
FYI
as fine of cuts there were on the Frame I did not want to stack cut both frames. I did stack cut the Frame. both sides and both the top & both at the same time.
I was concerned about cutting Cherry at a 1" thickness that fine. I cut 1" all the time for my Intarsia with with a # 5 skip reverse but with all the very small cuts in the Frame i had to drop down to a #2 to cut everything and was concerned with flexing the blade and ruining the piece.
I will stack cut the second Frame starting this week.
Far as a lot of cutting goes ---YESSSS! I have about 20 hours in the frame and about 15 hours in all the words.
Thank you for all the great comments.
Brian
Dick,
The maple pieces in the Cherry Frame are floaters in the pattern that have to be glued to the backer after the Frame was Glued. Pattern calls out you can cut them out of the same wood or an accent wood.
