edward Posted June 3, 2017 Report Posted June 3, 2017 Steve Good has a Pattern of a clock which has a 2 3/4" insert, now I was wondering if I could downsize it to a 1 3/8" insert, if so what percentage would I make it. Just wondering on peoples thoughts. Hope this isn't a stupid question. edward Quote
tuner Posted June 3, 2017 Report Posted June 3, 2017 Don't know if this will help any but i just cut a piece of paper the size of the insert i want then make smaller copies at the local office supply till i get a eye ball match.. No doubt there are math formulas but at .10 a copy it works for me.. And no, i don't think it was a stupid question GrampaJim 1 Quote
WayneMahler Posted June 3, 2017 Report Posted June 3, 2017 Edward I'm a firm believer in the only stupid question is the one you don't ask. So don't feel like that please. And the answer would be 50 %. What pattern is it. I may be able to resize the insert hole for you and keep the rest of the pattern normal. Another way would be to drill it out with a forstner bit, just hit the center of the hole. Quote
edward Posted June 4, 2017 Author Report Posted June 4, 2017 It is the Patriot clock, I tried 80% and still big. I think that I would have to resize all the pattern parts for it. edward Quote
jollyred Posted June 4, 2017 Report Posted June 4, 2017 The percentage to use is the desired size divided by the existing size times 100, For this example, it would be 2 3/4 divided by 1 3/8 which gives 50%. WayneMahler 1 Quote
WayneMahler Posted June 4, 2017 Report Posted June 4, 2017 (edited) If you want to maintain the original size less the clock insert. Here is a pattern redraw, use the red circle for the clock insert. thepatriot2.pdf Edited June 4, 2017 by WayneMahler Quote
spirithorse Posted June 4, 2017 Report Posted June 4, 2017 Jollyred was on the right wave-length but, had the formula wrong. Changing the dimensions to decimals, 2.75 divided by 1.375 is 2 or 200%. It should be 1.375 (the size you want) divided by 2.75 (the size of the original. That equals .5 which is 50% of the original size. Thanks to all the members that helped out. God Bless! Spirithorse Quote
munzieb Posted June 4, 2017 Report Posted June 4, 2017 I've done this on several of the clocks I've made. I typically take it to my copy store to get it close. They are willing to work with me to get it right and it's cheap. One thing to consider is that the clocks usually come with a spring loaded expansion ring or rubber ring that can be added to. Since you are cutting the hole for the clock, you can compensate for any minor difference in the dimension. Use a compass to make a size that will fit. The tower clock I made had an outer ring that was part of the design. That hole was an exact fit and the inner hole was close. bobscroll 1 Quote
edward Posted June 4, 2017 Author Report Posted June 4, 2017 Thanks for the help Guys, very helpful. edward Quote
hawkeye10 Posted June 4, 2017 Report Posted June 4, 2017 23 hours ago, edward said: Steve Good has a Pattern of a clock which has a 2 3/4" insert, now I was wondering if I could downsize it to a 1 3/8" insert, if so what percentage would I make it. Just wondering on peoples thoughts. Hope this isn't a stupid question. edward Yep this is a very stupid question. I also would like to know the answer. Quote
heppnerguy Posted June 5, 2017 Report Posted June 5, 2017 Well the answer to the math needed was given above, but for a red neck like me, I would print out the pattern as Steve Good designed it ' since only the insert hole is to be changed. then simply lay the insert in place and outline it with a sharp pencil. on the pattern and cut it on the inside of the pencil drawn on the pattern. then the clock is the same and the clock insert is the only thing changed. Dick heppnerguy Quote
munzieb Posted June 5, 2017 Report Posted June 5, 2017 Your post was much more succinct than mine. The KISS adage applies. Quote
amazingkevin Posted June 11, 2017 Report Posted June 11, 2017 On 6/3/2017 at 0:29 PM, edward said: Steve Good has a Pattern of a clock which has a 2 3/4" insert, now I was wondering if I could downsize it to a 1 3/8" insert, if so what percentage would I make it. Just wondering on peoples thoughts. Hope this isn't a stupid question. edward i use Rapid resizer for all this kind of work,I'm so happy to have found it! Quote
