Trka2002 Posted June 25, 2017 Report Share Posted June 25, 2017 I have been making a lot of my projects out of cedar because I came across a stock pile of it that will last me a very long time. The problem I have is with the finishing. I've been using a spray polyurethane but it takes a lot because it just soaks in, especially the end grain. I was wondering, for those who use cedar, what you use for a finish? Quote Link to comment Share on other sites More sharing options...
NC Scroller Posted June 26, 2017 Report Share Posted June 26, 2017 Try sanding sealer. It is a brush on product. Many companies make it. You can get it in Lowes, Home Depot and even Walmart. Jim Finn, WayneMahler and jollyred 3 Quote Link to comment Share on other sites More sharing options...
Falcon Posted June 26, 2017 Report Share Posted June 26, 2017 I agree with Scott and I think there is a 2 hour window after you put the sanding sealer on to put your finish over it. Jim Finn 1 Quote Link to comment Share on other sites More sharing options...
lawson56 Posted June 26, 2017 Report Share Posted June 26, 2017 Yea,about that long,works great.though it's been awhile since I used it. Quote Link to comment Share on other sites More sharing options...
WayneMahler Posted June 26, 2017 Report Share Posted June 26, 2017 I agree fully on the sealer. Works great on pine and poplar too. Keeps things from getting blotchy. I normally let mine set over night which means it is the last thing I do in my shop before closing up for the day. If you use a water based product gently wet it down first then lightly sand it when dry, this will eliminate the little raised pieces and give you a smoother finish. Quote Link to comment Share on other sites More sharing options...
Dan Posted June 26, 2017 Report Share Posted June 26, 2017 I use BLO/mineral spirit (50/50) on cedar. You can dip, wipe or brush it on. The first coat or two really soak in but additional coats will provide a nice, low luster finish. Scrolling Steve 1 Quote Link to comment Share on other sites More sharing options...
Trka2002 Posted June 27, 2017 Author Report Share Posted June 27, 2017 Thanks for the advice. I tryed it and it did make a big difference. Quote Link to comment Share on other sites More sharing options...
hawkeye10 Posted June 28, 2017 Report Share Posted June 28, 2017 On 6/25/2017 at 7:58 PM, Falcon said: I agree with Scott and I think there is a 2 hour window after you put the sanding sealer on to put your finish over it. Jerry I didn't know about the 2 hour window. More than likely I didn't read the instructions. I can't believe that. Quote Link to comment Share on other sites More sharing options...
Jim Finn Posted July 1, 2017 Report Share Posted July 1, 2017 I work mostly in cedar. I slop on a coat of shellac (lacquer also works) as a sealer. let it dry a few hours and sand it with 180 grit, tack cloth it and apply two or three coats of wipe on poly. Quote Link to comment Share on other sites More sharing options...
