I use spray glue to hold patterns but I was wondering what I could use for smaller patterns. The spray puts our a lot plus turning upside down is just a waste and a messy. I could put tape first then use white glue or whatever. Just want something you brush on or spread with a finger right on the wood.
42 minutes ago, Scrappile said:
Some use glue sticks.  I don't but I have read about it.
I used a glue stick while making my dominos. It did not hold very well but there is a good chance that it was a 15 year old glue stick...
I would still use the spray glue but to keep the mess down save your printer paper. I use a bigger piece of card board then put a used piece of printer paper on that and throw it away when finished. As for the expense  don't worry you have plenty on money.  :cool:
No spray glue used here.. I use full sheet shipping labels.. print my pattern out on them.. peel and stick.. They are pricey though if you get small quantities and or buy them local.. I get 1000 sheets at a time off eBay so I only have to order about 2 times a year.. Multi functional for me as my business is online so I do a lot of shipping anyway.
Kevin
No spray in this house (asthma sufferer).  I have used glue sticks, but mostly use white glue (Arlene's or Elmer's) over painters tape.  Works for me just fine.  The only down side is waiting for the white glue to dry, so plan ahead.
Jim
Xyron machine is what I use. I have the 9" and the 5". buy it with a 50% coupon from Micheals. It dry laminates adhesive to the back of the pattern and can be removable or permanent. I still use the blue tape under it.
Edited by Rolf
7 hours ago, Sycamore67 said:
I use 3M77 spray glue over blue tape.  I just use a quick spray and do not bother to try to clear nozzle.  I just have to scrape the nozzle off once in awhile.  I also bought some replacement nozzles on eBay.
Whenever I finish a can, I keep the nozzle in a jam jar with a little white spirit which I use to clear blocked nozzles.  That way I always have a few on hand.
Rob
Rob
I agree, and take it one step further. Each time I use Super 77 I take the nozel'off and put in a small container of mineral spirits.  If I were to invert the can can and clear the nozel off each time I would run out of propellant before I ran out of gas. 15 minutes of soaking will do the trick.
Not a fan of glue sticks.
If whatever spray adhesive is working - stick with it. To clean the nozzle, I remove it after a couple of uses, drop it into tinyl jar with turp and give it a shake. Keeps them running fine.
I have used gluesticks over painters tape. they work fine there but it seems like a wast to use painters tape with spray. It's a lot simpler to use spry by itself. I have an old piece of 1/4 ply to spray on and when it gets to bad to use I just get another piece of ply.
IKE
Turning a aerosol  can upside down to clear the nozzle is a waste.   The manufacturer is happy with those that use that method as they sell more product.   I quit doing that along time ago.   Like others have said there is a better way.
Edited by stoney
IKE
Ike, I use those free property magazines estate agents put out.  After spraying the pages stick together and you just turn the page and keep going until you run out then chuck it in the recycling.
Rob
On some small patterns such as ornaments, I just tape the pattern to the wood
with cellophane packing tape. I tape over the entire pattern since it is a small pattern
which helps lubricate the blade while cutting and keeps the entire pattern tight to the
wood.
God Bless! Spirithorse
Rob
wood.
I save every spray tip i can as i always run into troubl and can just go for a tip already been soaking for months Gets the job done that's what counts for me,i have jars full since 2004
  • 4 weeks later...
