jbrowning Posted July 10, 2017 Report Posted July 10, 2017 So I'm looking at getting a sanding mop to clean up the fuzzies that I have on my finished dragons. Is there a kit that has all the pieces in it that I will be needing to use the sanding mop? I have a drill press that I will be attaching this to. Thanks Jim Quote
munzieb Posted July 10, 2017 Report Posted July 10, 2017 Jim, about a year ago I started using a scotchbrite ball (red) that I found at Harbor Freight. I either use it on my drill press or on a hand held drill. Now, I almost never use sandpaper or an exacto knife to clean off cutting fuzz and I make sure I hit it from all directions. Even delicate cuts are not affected as long as I don't press too hard. For about $10, its worth a try. SCROLLSAW703 1 Quote
tonylumps Posted July 10, 2017 Report Posted July 10, 2017 Mac Mop.Very expensive but it works really well and lasts a long time. I use 2 grits 180 for rougher work and 220 just to ease the edges and the fuzzies.Very light touch does it Quote
Scrappile Posted July 10, 2017 Report Posted July 10, 2017 IF use the real "Sanding Mop" which is from Klingspor, you will need to buy a mandrill and then the grits of fillers you want. I have a Sanding Mop, it works great and I also have the Mac Mops, they work great also. I think the Mop is more for contoured pieces and the Mac for flat, but for what you want to do, either will work. A little spendy, yes, but like stated, last a long long time. Quote
hawkeye10 Posted July 10, 2017 Report Posted July 10, 2017 3 hours ago, jbrowning said: So I'm looking at getting a sanding mop to clean up the fuzzies that I have on my finished dragons. Is there a kit that has all the pieces in it that I will be needing to use the sanding mop? I have a drill press that I will be attaching this to. Thanks Jim Jim I have been using the Mac Mop and really like them. I use the 240 grit the most. http://www.woodworkingshop.com/product/mm07103/?inMed=GSTORE&dfw_tracker=18711-7848&gclid=Cj0KEQjwy4zLBRCOg6-4h6vs3cUBEiQAN-yzfn5Qz-uJ5OBsU1ERXE0_peFR17DiOz5aFRCvt1v7WdAaAsBN8P8HAQ Quote
bandaideman Posted July 10, 2017 Report Posted July 10, 2017 I agree with the above. Sanding mop I am not sure how long I have used it and still works well but has been years. Quote
amazingkevin Posted July 11, 2017 Report Posted July 11, 2017 8 hours ago, munzieb said: Jim, about a year ago I started using a scotchbrite ball (red) that I found at Harbor Freight. I either use it on my drill press or on a hand held drill. Now, I almost never use sandpaper or an exacto knife to clean off cutting fuzz and I make sure I hit it from all directions. Even delicate cuts are not affected as long as I don't press too hard. For about $10, its worth a try. I'm going to get one of those they look very gentle,Thanks! Quote
ScollSaw Slasher Posted July 11, 2017 Report Posted July 11, 2017 Run, don't walk to get yourself a sanding mop. You will not believe the amount of time and aggravation you'll save yourself. The scotch brite is a good little one for getting rid of the warm fuzzy s. I do a lot of intarsia, so the larger ones with the coarser grits especially are good for both sanding and shaping and then revert to the finer grit for just sanding. You will barely pick up the paper for hand sanding. Quote
jbrowning Posted July 11, 2017 Author Report Posted July 11, 2017 So the sanding mop I have to buy the mandrel and the sanding paper pieces and put together where are the Mac Mops come assembled already? If I go with the mac mops which size do you all suggest? As far as grits go, I was thinking like a 120 and a 220 should work for me. What do you all think? Am I missing something here? Thanks Jim Quote
Scrappile Posted July 11, 2017 Report Posted July 11, 2017 I have the 7" x 2", only size I have tried but I really like it. I have 180 and 240 grits and a 120 due by tomorrow. It appears to me that theys sand finer than the equal grit sheet paper. The 180 is the one I have ended up using the most and ordered the 120 grit for when I need more aggressive sanding. The only thing I have used the 240 for is light sanding over a finish like poly or shellac to smooth it. This is my experience, others may have different info. I have only been using them for about a month. I usually mount mine in my lathe to use. Quote
ScollSaw Slasher Posted July 11, 2017 Report Posted July 11, 2017 Agreed. The 120 and 180 would be the best starters as mentioned. And trust me, I'm not about to waste time making my own when they come already made and last a heck of a long time. Still on my first two and finally just considering getting a new 120 since i do quite a bit of shaping with my intarsia. Quote
tonylumps Posted July 11, 2017 Report Posted July 11, 2017 You can buy the Sanding Mop already put together. But very expensive also Like stated above using either one the grits will sand finer than the same grit in sanding sheets sanding sheets The 120 and 180 are perfect together Quote
Denny Knappen Posted July 11, 2017 Report Posted July 11, 2017 I bought my Mac Mop from Klingspor. 240 grit and it was complete with the spindle for about $40. Quote
Sycamore67 Posted July 11, 2017 Report Posted July 11, 2017 Sanding mops and Mac Mops are very different. I use a Mac Mop for more delicate sanding like on smaller puzzle pieces. I do most of my Intarsia sanding and shaping with a pneumatic sanding drum and finish with the sanding mop. Quote
jbrowning Posted August 3, 2017 Author Report Posted August 3, 2017 Just a little follow up to the sanding mop situation. I ended up getting the mac mop and it did a great job on the outside of the pieces, but what do you use for the inside of the pieces? Is there a smaller sanding mop that works for this or is it done by hand? Thanks Jim Quote
Woodmaster1 Posted August 5, 2017 Report Posted August 5, 2017 Glad I looked at the post because I was going to harbor freight this week. Quote
Scrappile Posted August 5, 2017 Report Posted August 5, 2017 On 8/3/2017 at 5:46 AM, jbrowning said: Just a little follow up to the sanding mop situation. I ended up getting the mac mop and it did a great job on the outside of the pieces, but what do you use for the inside of the pieces? Is there a smaller sanding mop that works for this or is it done by hand? Thanks Jim By turning or slanting the piece, I an able to get a lot of the frizzies with the mac mop. I mount my Mac Mop on my lathe. There are two other tools I use for what I can't get. I scrape with an X-acto knife blade, small one, and a fine wire brush in my Dremel works great also. Quote
Rolf Posted August 6, 2017 Report Posted August 6, 2017 I use the 2" wide spindle mounted mac mops 180 and 240 grits on everything, including my fretwork. gently with a support board behind it. Like Denny said $40 but they last a very long time. They seem to be less aggressive than the regular mops and lat longer http://www.woodworkingshop.com/product/mm07204/ Quote
