I never realized it but you can resize a pattern in Gimp 2 to print it.  I always had rapid resizer but don't have the money for it right now.  I don't know if anyone else knew it but hope it helps.
gimp is way over my head to operate
On ‎7‎/‎18‎/‎2017 at 3:08 PM, Roberta Moreton said:
What would work on an iPad for this?  I no longer have a computer.
Sorry I have never have never used that. Gimp is the only other program I know.
So how do you resize in gimp? is it quick and simple? I do a lot of resizing and I use a couple different methods depending on what I am working with..
1) is I use posterazer.. free download.. you just put in your image and select boarders if needed.. you can resize by % and in inches mm etc.. then it saves it to a PDF file.
2) certain patterns I will resize by just right clicking the image file and click print. then it brings up options for the size and you can change the number of copies per sheet.. I typically do this for my Christmas ornaments and do them as a 4 x 6 then click 4 per full sheet
I use excel.. open blank workbook.  insert picture.  drag to size you want.  Switch to page layout view and you can see how many pages it will take and adjust accordingly.  It will print across multiple pages just fine, just trim and tape together.
Also works with the free version of excel or whatever it is called.
i USE pHOTOSUIET. iT CAME WITH MY FIRST COMPUTOR WINDDOWS 95 AND i STILL USE IN ON WINDOWS 10 IT'S DQUICH AND SIMPLE BUT IT ONLY DOES A 8X12 WHICH COVERS MOST EVERYHTING I USE.
IKE
