hotshot Posted July 28, 2017 Report Posted July 28, 2017 (edited) On the Accessory arm, there are some holes (above the air line) meant to be used to hold the clamps steady while you tighten the blades. This isn't quite a sophisticated as the Hegner approach, but I think it will work fine. Of course, my saw didn't have the hole drilled in the correct location for their newer clamps Nilus said the existing holes were for prior blade clamps, but that they would add the third hole for the current clamps going forward. I have no warranty (for multiple reasons), so they are not obligated nor did they offer to fix it, which is ok, because I have a tweak that will work for me. So the forward hole that supposed to fit my clamp, per the manual is too low. There is nothing I can do about that without grinding into the arm. The second hole, which was for some other clamp is too high, so I can work with that. That just means I have to find a spacer and glue there to make it fit. So I rolled a piece of metal (A Fat Coin) to a thickness of .066", and glued it above the second hole. If it stays there, it will work fine. Here is how it supposed to work according to the Manual First Hole Intend for this per the diagram above, but too low Second Hole Intended for another Clamp Type, but too High Here is the fix with the metal Spacer SuperGlued into Place Edited July 28, 2017 by hotshot Lucky2 1 Quote
Iguanadon Posted July 28, 2017 Report Posted July 28, 2017 Nice. I'm actually not even removing the lower blade clamp when I replace blades... I just feed it down thru the hole in the table, insert it into the clamp and tighten it. So far so good. LOL We'll see if I keep the blade properly aligned when I do it. That's how I've always done it on my Dewalt, so I have pretty good hand/eye coordination although it was easier on the Dewalt. Quote
trackman Posted July 28, 2017 Report Posted July 28, 2017 You sound like Goldelocks and the 3 bears Hotshot LOL Quote
hotshot Posted July 28, 2017 Author Report Posted July 28, 2017 1 hour ago, trackman said: You sound like Goldelocks and the 3 bears Hotshot LOL Except I had to make my own porridge that was just right :-) Quote
amazingkevin Posted July 29, 2017 Report Posted July 29, 2017 5 hours ago, hotshot said: On the Accessory arm, there are some holes (above the air line) meant to be used to hold the clamps steady while you tighten the blades. This isn't quite a sophisticated as the Hegner approach, but I think it will work fine. Of course, my saw didn't have the hole drilled in the correct location for their newer clamps Nilus said the existing holes were for prior blade clamps, but that they would add the third hole for the current clamps going forward. I have no warranty (for multiple reasons), so they are not obligated nor did they offer to fix it, which is ok, because I have a tweak that will work for me. So the forward hole that supposed to fit my clamp, per the manual is too low. There is nothing I can do about that without grinding into the arm. The second hole, which was for some other clamp is too high, so I can work with that. That just means I have to find a spacer and glue there to make it fit. So I rolled a piece of metal (A Fat Coin) to a thickness of .066", and glued it above the second hole. If it stays there, it will work fine. Here is how it supposed to work according to the Manual First Hole Intend for this per the diagram above, but too low Second Hole Intended for another Clamp Type, but too High Here is the fix with the metal Spacer SuperGlued into Place Your a man of many talents i see,Expect a dozen Dewalts on your door step if you lived closer,lol Quote
hotshot Posted July 29, 2017 Author Report Posted July 29, 2017 3 minutes ago, amazingkevin said: Your a man of many talents i see,Expect a dozen Dewalts on your door step if you lived closer,lol If I was closer, I would take one off of you. I would love to try the 788 refresh. Quote
