tonylumps Posted August 1, 2017 Report Posted August 1, 2017 I bought my EX about a year ago.So I am guessing it is about 3 years old So I figured i would do a little Maint.on it.I replaced the Top blade clamp.Don't think I needed it While I had it apart i repacked all of the needle bearings on the front of the saw.Just what everybody was talking about EX does have greased bearings So all of the bushings looked good.Did not tear the back end apart.I think I will wait on that.A little more complicated.its not broke so I will leave it.Looking at my 19 year old Hegner sitting next to it I figured It was do for Maint..So 4 drops of 3 in1 oil did the trick.Good for 2 more weeks Lucky2 1 Quote
Rob Posted August 1, 2017 Report Posted August 1, 2017 I'm sure you meant years, not weeks for the Hegner maintenance! Rob Quote
tonylumps Posted August 1, 2017 Author Report Posted August 1, 2017 1 hour ago, Rob said: I'm sure you meant years, not weeks for the Hegner maintenance! Rob If I use mobile 1 Synthetic Quote
hotshot Posted August 2, 2017 Report Posted August 2, 2017 3 hours ago, Rob said: I'm sure you meant years, not weeks for the Hegner maintenance! Rob I use 3 in 1 every time I use the Hegner. The manual says every 10 hours, but it's easier for me to remember if I just do it before every use. Quote
amazingkevin Posted August 2, 2017 Report Posted August 2, 2017 17 hours ago, tonylumps said: I bought my EX about a year ago.So I am guessing it is about 3 years old So I figured i would do a little Maint.on it.I replaced the Top blade clamp.Don't think I needed it While I had it apart i repacked all of the needle bearings on the front of the saw.Just what everybody was talking about EX does have greased bearings So all of the bushings looked good.Did not tear the back end apart.I think I will wait on that.A little more complicated.its not broke so I will leave it.Looking at my 19 year old Hegner sitting next to it I figured It was do for Maint..So 4 drops of 3 in1 oil did the trick.Good for 2 more weeks Oh Lord ,3 in one oil is so thin it will run out fast.car axle grease will be there from now on . Quote
amazingkevin Posted August 2, 2017 Report Posted August 2, 2017 5 hours ago, hotshot said: I use 3 in 1 every time I use the Hegner. The manual says every 10 hours, but it's easier for me to remember if I just do it before every use. My DW788's love heavy grease and as wore out as i get them it brings them back to factory specs,just my 2 cents Quote
hawkeye10 Posted August 2, 2017 Report Posted August 2, 2017 (edited) 6 hours ago, amazingkevin said: My DW788's love heavy grease and as wore out as i get them it brings them back to factory specs,just my 2 cents I don't know if you have watched the video on You Tube about maintenance on the DW788 but he tells you what the best grease is to use. He also tells you where to buy bearings that are better and cost less. If it were me I would use the best. Edited August 2, 2017 by hawkeye10 Quote
tonylumps Posted August 2, 2017 Author Report Posted August 2, 2017 (edited) I did not replace bearings in this saw.Just repacked them Because they were packed with grease when the saw was put together .Dewalt has that problem.no grease when put together is why they need bearings after a year. I have been using Timken bearing Grease all my life I still own 2 trailers and that is what I use for them.I am sure it will work on any scroll saw made. Edited August 2, 2017 by tonylumps JimErn 1 Quote
