johnnyo Posted August 5, 2017 Report Posted August 5, 2017 What is the recommended glue to stick patterns onto the wood for scrolling? Quote
WayneMahler Posted August 5, 2017 Report Posted August 5, 2017 I use 3M 77 on the back of the pattern then apply it over blue painters tape. johnnyo 1 Quote
kmmcrafts Posted August 5, 2017 Report Posted August 5, 2017 I use full sheet shipping labels..unless it's a large pattern then I use 3M 77 Quote
johnnyo Posted August 5, 2017 Author Report Posted August 5, 2017 (edited) 28 minutes ago, WayneMahler said: I use 3M 77 on the back of the pattern then apply it over blue painters tape. Thanks for your help.So it should be used on the back of of the wood or does it matter if it's the good side? Edited August 5, 2017 by johnnyo Quote
johnnyo Posted August 5, 2017 Author Report Posted August 5, 2017 18 minutes ago, kmmcrafts said: I use full sheet shipping labels..unless it's a large pattern then I use 3M 77 Thanks for your reply. Can you recommend where I can buy full sheet shipping labels?do you copy the patterns onto them? Is 3M77 in a spray can, & can it be purchased in a lumber yard or would I have to get it at a hobby shop? Quote
rjweb Posted August 5, 2017 Report Posted August 5, 2017 3m 77 can be purchased at Home Depot or lowes, also some strollers purchase shelf lining at amazon or Walmart and glue there pattern to that, RJ johnnyo 1 Quote
MrsN Posted August 5, 2017 Report Posted August 5, 2017 I use regular craft glue sticks. I stock up this time of year when the school supplies are on sale. I use this method because I don't like the fumes of spray glue. Montserrat, SCROLLSAW703, johnnyo and 1 other 4 Quote
johnnyo Posted August 5, 2017 Author Report Posted August 5, 2017 26 minutes ago, rjweb said: 3m 77 can be purchased at Home Depot or lowes, also some strollers purchase shelf lining at amazon or Walmart and glue there pattern to that, RJ With shelf lining would they copy the pattern to it, or print directly to it? thanls Quote
johnnyo Posted August 5, 2017 Author Report Posted August 5, 2017 10 minutes ago, MrsN said: I use regular craft glue sticks. I stock up this time of year when the school supplies are on sale. I use this method because I don't like the fumes of spray glue. Does it clean off the wood good? Quote
amazingkevin Posted August 5, 2017 Report Posted August 5, 2017 2 hours ago, johnnyo said: What is the recommended glue to stick patterns onto the wood for scrolling? No matter how much i sand i can never get all the glue off so painter tape will save a lot of fuss johnnyo 1 Quote
WayneMahler Posted August 5, 2017 Report Posted August 5, 2017 1 hour ago, johnnyo said: Thanks for your help.So it should be used on the back of of the wood or does it matter if it's the good side? I put my patterns on the good face of the wood. Painters tape peels off pretty easy, just be careful around the "fragile" areas of your work. johnnyo 1 Quote
johnnyo Posted August 5, 2017 Author Report Posted August 5, 2017 18 minutes ago, WayneMahler said: I put my patterns on the good face of the wood. Painters tape peels off pretty easy, just be careful around the "fragile" areas of your work. Thanks Quote
johnnyo Posted August 5, 2017 Author Report Posted August 5, 2017 20 minutes ago, WayneMahler said: I put my patterns on the good face of the wood. Painters tape peels off pretty easy, just be careful around the "fragile" areas of your work. Great thanks Quote
Phantom Scroller Posted August 5, 2017 Report Posted August 5, 2017 Spray re-positional glue with 2" sellotape on top works everytime for me and easy to remove hence re-positional. Roly Quote
johnnyo Posted August 5, 2017 Author Report Posted August 5, 2017 7 hours ago, Phantom Scroller said: Spray re-positional glue with 2" sellotape on top works everytime for me and easy to remove hence re-positional. Roly where would I get re-positional glue, and sorry I don't follow about using 2" sellotape on top. John Phantom Scroller 1 Quote
edward Posted August 5, 2017 Report Posted August 5, 2017 I use 3M 77 on back of patterns then adhere to painters blue tape on the project. edward johnnyo 1 Quote
tuner Posted August 5, 2017 Report Posted August 5, 2017 There are a lot of different ways of doing this. Don't thing there is a right or wrong way. 3m 77 works, so does just about any spray glue. Glue sticks. Even watered down white glue. All methods have pro's and con's. Some glue the pattern to the wood, some to tape, shelf lining, ect. Some go the extra step of clear packing tape over everything. I believe it holds the pattern better and is said to lubricate the blade. Try different ways see what works for you. johnnyo 1 Quote
crupiea Posted August 5, 2017 Report Posted August 5, 2017 I use the cheapest generic spray glue they sell at walmart. no idea what the brind is. Spray a super light coat in the back of the paper, super light coat, like 1 second for the whole pattern. Now wait a few minutes so it is just barely tacky. Picture a post it note amount of stickiness, thats almost too much but will work. apply it to the wood. It will stay on just fine and peel right off when done. johnnyo 1 Quote
johnnyo Posted August 6, 2017 Author Report Posted August 6, 2017 7 hours ago, crupiea said: I use the cheapest generic spray glue they sell at walmart. no idea what the brind is. Spray a super light coat in the back of the paper, super light coat, like 1 second for the whole pattern. Now wait a few minutes so it is just barely tacky. Picture a post it note amount of stickiness, thats almost too much but will work. apply it to the wood. It will stay on just fine and peel right off when done. Thanks much, will try all suggestions. Quote
kmmcrafts Posted August 6, 2017 Report Posted August 6, 2017 23 hours ago, johnnyo said: Thanks for your reply. Can you recommend where I can buy full sheet shipping labels?do you copy the patterns onto them? Is 3M77 in a spray can, & can it be purchased in a lumber yard or would I have to get it at a hobby shop? They can be purchased at most any office supply store...however kind of pricey there.. I buy packs of 500 or 1000 from a eBay seller.. while a big chunk of money up front,, way cheaper than small amounts at a office supply store.. I also use the shelf liner.. put it down on the wood... print the pattern on the label paper.. peel and stick to the shelf liner that is already been placed into the wood.. I like this method over the spray glues etc as there is a lot of mess around the spray glues from over sprays.. This is simple and clean.. Quote
Montserrat Posted August 6, 2017 Report Posted August 6, 2017 craft glue stick works perfectly, and comes off easily. I also avoid spray bottles! Quote
Phantom Scroller Posted August 6, 2017 Report Posted August 6, 2017 15 hours ago, johnnyo said: where would I get re-positional glue, and sorry I don't follow about using 2" sellotape on top. John Re-positional glue is strong enough to stay in place and the tape is there to give the blade a lubricant and peels off easier with it stuck on top you can buy it at any craft shop or sometimes at the cheaper shops like poundland etc. Roly Quote
Docupton Posted August 6, 2017 Report Posted August 6, 2017 I use Craft supplies re-positional glue, i spray the back of the pattern and and put it directly on to the wood, stays put, removes easy and little or no residue. Phantom Scroller 1 Quote
Rolf Posted August 6, 2017 Report Posted August 6, 2017 I use the Xyron machine. No spray adhesive. Quote
johnnyo Posted August 6, 2017 Author Report Posted August 6, 2017 WOW, I never would of thought of all these available options. Thanks all. I will see what is available in my area, & will follw up on them. John Phantom Scroller 1 Quote
