This is the first part of 2 clocks I am making for Father's Day. This is the centerpiece for the first one. It's a wild turkey pattern cut from approx 1/16" copper. Had a heck of a time photographing it with a flash, as the copper wanted to REALLY reflect it and wash the lines out. Yes, it got a little nerve-racking on the feathers...lots of vibrating up and down when you get to not much holding it all together. I am going to mount it on a piece of Claro Curly Walnut with a Westminster Chimes movement...and a few other modifications ;) will post pics of it thru the process...
Pics are here:
That's looking great. I bet the copper will make it really stand out. I can't wait to see the final product Good job! :thumbs:
BTW, if you sandwich the copper between two pieces of 1/8" ply, you'll save yourself some gray hairs. That way it won't flex as you saw the pattern out.
  • 2 weeks later...
Well...one step closer on both clocks. Laid the copper and brass pieces on the wood and took a few pics to see how it looks.
http://www.scrollsawvillage.com/gallery/displayimage.php?pos=-4094 Deer
http://www.scrollsawvillage.com/gallery/displayimage.php?pos=-4095 Turkey
The deer pattern is reversed from what the pattern actually is. I cut out the normally discarded pieces instead. Kind of a different look. Thought the letter being cut from different metal to the rest sets it off a little.
More work to do!!....don't know if I'll get them done before Father's Day, :scared: but should be close.
Thanks for the previous comments too! :D
Slowly making progress...needless to say, don't see them getting done for Father's Day :boo:
Here are some pics of the progress now....have both rough sanded and the mounting holes drilled for the bases. Now the fun, dusty part of getting them sanded smooth for varnishing. Going to put a few coats on so it has a good gloss to it. Pics really don't do justice to the way the walnut and maple will look with the finish on them...more to come....
http://www.scrollsawvillage.com/gallery/displayimage.php?pos=-4116
http://www.scrollsawvillage.com/gallery/displayimage.php?pos=-4115
http://www.scrollsawvillage.com/gallery/displayimage.php?pos=-4114
Finally just about finished...got the final coats of varnish applied to the base and clock, then put on the crystals for the clock positions and glued the metal pieces in place. Still have to varnish the bottom of the clock and base, but decided to put them together temporarily and take a pic of them outside in the sun so the flash of the camera would not glare things out.
http://www.scrollsawvillage.com/gallery/displayimage.php?pos=-4158
http://www.scrollsawvillage.com/gallery/displayimage.php?pos=-4157
