amazingkevin Posted August 13, 2017 Report Posted August 13, 2017 I've been able all these years to enlarge patterns and words but for the life of me i can't enlarge some words to fit in a space 10.5" x11' ="Live happy healthy and free".The letters need to be horizontal instead of vertical with spaces between each and at the beginning and at the end.No quotation marks. bobscroll, neptun, lawson56 and 1 other 4 Quote
DWSUDEKUM Posted August 13, 2017 Report Posted August 13, 2017 Nicely done world there Kevin. As for the others create each word as a separate vector layer then arrange and size to your content then just merge the layers when you are satisfied you like it. DW Quote
lawson56 Posted August 13, 2017 Report Posted August 13, 2017 Fantastic job Kevin!I have met a few of those in my time.I agree with DW.I have had to do that on several occasions. Quote
amazingkevin Posted August 14, 2017 Author Report Posted August 14, 2017 22 hours ago, DWSUDEKUM said: Nicely done world there Kevin. As for the others create each word as a separate vector layer then arrange and size to your content then just merge the layers when you are satisfied you like it. DW Well i thought of that but it needs to fit in a certain space .I can't pattern and cut the wood and not have it fit.I'm not all that smart to get it right the first time. Quote
amazingkevin Posted August 14, 2017 Author Report Posted August 14, 2017 19 hours ago, lawson56 said: Fantastic job Kevin!I have met a few of those in my time.I agree with DW.I have had to do that on several occasions. If i fold the pattern in half and go from there sounds good on paper.One thing I'm short of is time so i need to get it right the first time. lawson56 1 Quote
wombatie Posted August 14, 2017 Report Posted August 14, 2017 Great cutting. Sorry can't help you with your problem. Marg Quote
amazingkevin Posted August 15, 2017 Author Report Posted August 15, 2017 21 hours ago, wombatie said: Great cutting. Sorry can't help you with your problem. Marg Thanks Marge i already got paid for it too and for the life of me cannot print it to size. Quote
meflick Posted August 16, 2017 Report Posted August 16, 2017 Kevin, before I attempt to help. Can you answer a couple of questions - first, do you really mean 10.5 inches high and 11 FEET long for your pattern? Second, what font are you wanting to use to create the pattern? Do you want each word capitalized? Do you want the word "and" or do you want the and symbol like this "&"? I have a program that I might could try to create this in for you but before I do give it a try, it would be beneficial to have that information on the front end. Quote
amazingkevin Posted August 18, 2017 Author Report Posted August 18, 2017 (edited) On 8/16/2017 at 7:36 AM, meflick said: Kevin, before I attempt to help. Can you answer a couple of questions - first, do you really mean 10.5 inches high and 11 FEET long for your pattern? Second, what font are you wanting to use to create the pattern? Do you want each word capitalized? Do you want the word "and" or do you want the and symbol like this "&"? I have a program that I might could try to create this in for you but before I do give it a try, it would be beneficial to have that information on the front end. The words are LIVE HAPPY HEALTHY AND FREE Hi Melanie,Somehow i forgot how to enlarge things.All the letters are capitals and the & can be the word and,She wanted acme letters but there are so many similar ones take your pick.The words go on a column side ways or horizontal to fit in a space 11' long and each letter is 10.5" tall with spaces at the beginning and end and in between the words.I've wasted so much ink and paper and time trying i gave up.I'm not getting much for it but it's more than i have ! A labor of love. Edited August 18, 2017 by amazingkevin CRS Quote
don watson Posted August 19, 2017 Report Posted August 19, 2017 Kevin, I am still at a loss to fully understand your problem. Are the words to go on a vertical column ?? or across a horizontal row ?? Are you cutting the 23 letters from 23 pieces of A4 (or whatever the American equivalent is) of wood ? Can they not be cut as usual, ie across as a row and then turned sideways ? I am getting confused myself now Is this being cut from 1 piece of wood ?? Don W Quote
WayneG Posted August 19, 2017 Report Posted August 19, 2017 Kevin I had a request for a monogram so large that I could not print it off, I ended up hand writing it and then tracing the pencil lines once safistfied with a sharpie....sounds to me that may be the way should go. Take a smaller sample and then tape pieces of paper together and start to draw the font Quote
Dan Posted August 19, 2017 Report Posted August 19, 2017 (edited) Hey Kevin, I'm not sure what you are looking for but I threw this together for you. Will it work? Oops! I sho uld have checked my work first. I'll have it for you in a few minutes. OK, try this. Live.pdf Edited August 20, 2017 by Dan Quote
meflick Posted August 19, 2017 Report Posted August 19, 2017 @Dan- what I see when I open your PDF is the H is missing from the word Happy so its Live Appy Quote
Dan Posted August 19, 2017 Report Posted August 19, 2017 (edited) 40 minutes ago, meflick said: @Dan- what I see when I open your PDF is the H is missing from the word Happy so its Live Appy Hehe... Thanks for the proofread. It's now fixed. Edited August 20, 2017 by Dan meflick 1 Quote
amazingkevin Posted August 20, 2017 Author Report Posted August 20, 2017 inresponce to the delima i had the ladys son do it at work.they really knocked my pay way down for that.My mistake also .I knocked it out way to fast and delieved it .they were shocked i did it so fast.thinks you'll do when your hungry`!so far all the work i ve done for her i didn't even get minimum wage.she taped them on the 11' column and then there's me loaded with routed chips as she wanted round edgesit took an hour to rout the edges in my lap with a ryobe router with a piece of formica glued on the bottom so i could route upside down in my lap Quote
newfie Posted August 20, 2017 Report Posted August 20, 2017 Looks good Kevin thanks for sharing Quote
amazingkevin Posted September 29, 2017 Author Report Posted September 29, 2017 On 8/20/2017 at 5:49 AM, newfie said: Looks good Kevin thanks for sharing Thanks Todd for taking the time to look see,lol Quote
