I tried searching for the answer but I guess I didn't phrase it correctly. I'm still a novice so maybe this is a question that has been asked before. I'm sure it is. Anyway, I'm going to try my luck at making a set of nut bowls out of pine. If I succeed I'll try some exotic wood but for now, it's going to be out of what I have laying around. The pine is 3/4 inch thick and not really too hard. So, how do I go about choosing the right blade? I have a good selection of blades but I really don't know what tooth pattern or size to use. I'm thinking a number 5 but from there I'm lost. Can any of you offer your expertise here? I'd certainly appreciate it.
Ray
im with ike, a #5 or #7 polar blade if it was me, but you could use a skip tooth, or even ultra reverse if the urge hit ya. My preference is the skip tooth or polar blade. which ever cuts the bets. Pay attention in your pine. the blade may have a tendency to follow the grain of the of the wood.
Thanks for the help. I have just been chatting with Iguanadon. He recommends pretty much the same as both of you. He uses Olsen Mach Speed #3 reverse skiptooth.
I don't have any of those but will soon purchase some.
Ray
A #5 reverse tooth is my go to size for 1/2" or greater.  I have and still use many brands and style blades though mostly Pegasus.  Instead of playing with pine use poplar.  Due to the grain pine is actually harder to get a true cut on especially when cutting with the grain.
Good luck and hope to see pictures soon.
Ray
I would use #3 and #5 Pegas MG blades. Just try a few. I bet you will like them. The main reason I like them is you feed the wood straight into the blade much like you would a jig saw. Other blades you have to feed them in an angle.
I couldn't agree more.
The only reason I'm going to use pine is I have a scrap large enough to get 4 bowls out of it. But, after talking with IguanaDon, I might just have to run over to Lowe's and buy some poplar. I've never worked with poplar before so I welcome the experience.
I sure do want to thank all of you who chimed in on my inquiry.
Ray
i agree on poplar,pine grain makes your blade wander.
Pine can be tough to cut but if you are take your time and use a sharp blade it is okay.
I am starting my Christmas ornaments and I have cut the body in 3/4 inch pine.  I used FD Ultra Reverse #3 for all the interior detail and not an issue so far.  I used FD-UR for the exterior.  What I like about the UR is that the surface does not need to be sanded.  I used FD-UR #5 on exterior.
I also cut a prototype in 1 inch and didn't have any issues.
I like the pine as this will be decorated and painted by the boss.
Only have 16 more to go and 34 of the feet.
Hey Don, I like that. What is the size of it? And where did you get the pattern if I may ask?
Ray
