Bob Puhlman Posted September 1, 2017 Report Posted September 1, 2017 Where is there a delta service center For a scroll saw within 200 miles of High Point, NC Quote
OCtoolguy Posted September 1, 2017 Report Posted September 1, 2017 Is your saw still under warranty? What is the problem with it. The reason I ask is, once you take it in, you may not have it for a while so if it's something simple to fix you may be able to do it yourself. There are so many videos on youtube now, you can fix most anything that normally goes haywire. I have a DW788 and the Delta saws of late are mostly a copy of that saw. Ray WayneMahler 1 Quote
amazingkevin Posted September 2, 2017 Report Posted September 2, 2017 8 hours ago, octoolguy said: Is your saw still under warranty? What is the problem with it. The reason I ask is, once you take it in, you may not have it for a while so if it's something simple to fix you may be able to do it yourself. There are so many videos on youtube now, you can fix most anything that normally goes haywire. I have a DW788 and the Delta saws of late are mostly a copy of that saw. Ray I used to like to fix other peoples stuff but not mine? Quote
NC Scroller Posted September 2, 2017 Report Posted September 2, 2017 There is a Dewalt service shop in Raleigh NC. They repair Delta as well. But there's one closer to you in Greensboro. DeWalt / Delta | Porter-Cable Factory Service #0713402 West Wendover Avenue Greensboro, NC 27407 USATelephone: 336-852-1300 Approximate distance: 8.3 miles Quote
