Long straight cuts
malc
i had that problem a few times and learned that the thinest pencil line helps keep you going straight as you'll see right away that you're starting to go off course and going very slow worked out the best for me.The grain of the wood tends to make the blade wander so make sure the blade tention is tight too.Great question ,somebody needs to come out with a book of all the tips and tricks we need to know and refresh ourselves now an then. :)
Your blade is going to want to drift. You need to compensate for this by feeding your wood at an angle. Go slow and watch ahead of your blade slightly and cut toward a point in front of the blade rather than following the line. Once you try what I'm trying to describe you will understand.
Mainly it is practice, and prayer that the blade won't catch the grain of the wood and go sideways. If it does then it is finesse' sanding...LOL
Straight - line cutting across the grain and with the grain takes practice also a couple of factors have to be taken into consideration . first almost all scroll saw and fret saw blades dont cut straight or cut parallel to the blade they often cut a few degrees more towards one side than the other . When you stand facing the direct front of the saw you will note that the angle of normal feed is off approximately 2 to 4 degrees to compensate You can verify this for yourself Draw some lines across a board with a square now cut each line you will soon determine that its easiest to follow the line with the work feed slightly angled into the saw blade Straight line ripping is done in essentially the same way However be alert because the blade may follow the grain rather than the layout as you expect. in such cases slow the feed and compensate by changing the angle slightly more in the appropriate direction . with some pratice straight line sawing freehand is surprisingly easy even when using very narrow blades . Joe
  • 3 weeks later...
I thought I might be able to add a little advice to the already great suggestions on this topic. Doing some of the larger projects I do, I cut a lot of straight lines. Therefore, through plenty of practice, I'm consider myself pretty good at it. Still though, there are times I come across a piece of wood that just will not let me cut a straight line no matter how I hold my tongue, or my wood. Therefore, I have a method to my straight lines. I always cut them first when possible. That way, if I get so far off while doing the staightaways that I'm not happy with it, I can scrap that piece of wood without already haveing a lot of time invested in that particular piece of wood. When I'm not able to cut the straights first, then I make sure I have a sharp blade. Those little suckers are straonger than you may think. Just because they are still cutting doesn't mean they are sharp. I have found that a dull blade will still cut for some time, but not very straight. So, with a sharp blade, I cut with the saw at a high speed, but while moving my wood at a very slow speed. I hope that makes much sense.
