blights69 Posted September 21, 2017 Report Posted September 21, 2017 Had a little time so stack cut 3 of these today from Vinyl, coloured with spray cans Dave Monk, Scrolling Steve, frankorona and 4 others 7 Quote
DWSUDEKUM Posted September 21, 2017 Report Posted September 21, 2017 Very nicely done Frank. Thanks for sharing them with us. DW blights69 1 Quote
Scrappile Posted September 21, 2017 Report Posted September 21, 2017 Back at it and look'n mighty good! blights69 1 Quote
Aggie Posted September 21, 2017 Report Posted September 21, 2017 Nice cuts there, great job. blights69 1 Quote
penquin Posted September 22, 2017 Report Posted September 22, 2017 Looks great, what blades are you doing it with. If you don't mind kindly advise would love to try some records. Thanks jim penquin blights69 1 Quote
newfie Posted September 22, 2017 Report Posted September 22, 2017 Those are cool thanks for sharing blights69 1 Quote
wombatie Posted September 22, 2017 Report Posted September 22, 2017 Very nice Frank. Well done. Marg blights69 1 Quote
blights69 Posted September 22, 2017 Author Report Posted September 22, 2017 5 hours ago, penquin said: Looks great, what blades are you doing it with. If you don't mind kindly advise would love to try some records. Thanks jim penquin I use Pegas #2 & Olsen #4 both spiral. I do find with the small lines on #2 the line or cut out tends to melt back in you have to cut quick or go over the cut line again to pop it out that mainly happens more when you stack cut them, I clean the cut as I go so the vinyl cannot set back in along the cut lines I use a toothbrush works a treat for me others may use different blades clean up ways etc but this suits me . Hope that helps Jim Quote
lawson56 Posted September 22, 2017 Report Posted September 22, 2017 Frank,they are just Fantastic.I know there all the same pic,but I like the middle 1 best. blights69 1 Quote
Roberta Moreton Posted September 22, 2017 Report Posted September 22, 2017 You can spray paint them!?? blights69 1 Quote
Dave Monk Posted September 23, 2017 Report Posted September 23, 2017 Lookin great Frank. blights69 1 Quote
blights69 Posted September 23, 2017 Author Report Posted September 23, 2017 9 hours ago, Roberta Moreton said: You can spray paint them!?? Spray paint goes on them no problems at all Quote
penquin Posted September 23, 2017 Report Posted September 23, 2017 On 9/22/2017 at 0:38 AM, blights69 said: I use Pegas #2 & Olsen #4 both spiral. I do find with the small lines on #2 the line or cut out tends to melt back in you have to cut quick or go over the cut line again to pop it out that mainly happens more when you stack cut them, I clean the cut as I go so the vinyl cannot set back in along the cut lines I use a toothbrush works a treat for me others may use different blades clean up ways etc but this suits me . Hope that helps Jim Thanks for the help, don't use spirals only flats, sort of old school for me. Will try some 2 and 3 don't think I can find 4's. Was wondering if you used reverse tooth blades or not but don't believe most spirals are reverse. Thanks again for taking the time to get back to me. jim Quote
blights69 Posted September 23, 2017 Author Report Posted September 23, 2017 1 hour ago, penquin said: Thanks for the help, don't use spirals only flats, sort of old school for me. Will try some 2 and 3 don't think I can find 4's. Was wondering if you used reverse tooth blades or not but don't believe most spirals are reverse. Thanks again for taking the time to get back to me. jim I also do not like the spirals but on the vinyl no choice normal blades just chip the vinyl Good luck if you give it a go Quote
