Roberta Moreton Posted September 30, 2017 Report Posted September 30, 2017 This is from the Fall 2017 issue of SSWW. I cut it this past weekend. Then I had to find a base. That always takes a bit of time, I stash unusual pieces I find in other woodworking garbage. Mostly pieces to bad for furniture builders. The eagle s cherry, the base is oak. New Guy, Sam777, jollyred and 2 others 5 Quote
New Guy Posted October 1, 2017 Report Posted October 1, 2017 That is top notch work. Like the wood used, Bet you are seeing holes in your sleep. Quote
DWSUDEKUM Posted October 1, 2017 Report Posted October 1, 2017 Very nicely done. Thanks for sharing this with us. DW Quote
amazingkevin Posted October 1, 2017 Report Posted October 1, 2017 5 hours ago, Roberta Moreton said: This is from the Fall 2017 issue of SSWW. I cut it this past weekend. Then I had to find a base. That always takes a bit of time, I stash unusual pieces I find in other woodworking garbage. Mostly pieces to bad for furniture builders. The eagle s cherry, the base is oak. Gorgeous to see,Love that wood used ,You've an eye for details ! Quote
lawson56 Posted October 1, 2017 Report Posted October 1, 2017 The Base is just Fantastic!!! So is the Eagle Quote
blights69 Posted October 1, 2017 Report Posted October 1, 2017 Great choice of wood and a great cut too Quote
wombatie Posted October 2, 2017 Report Posted October 2, 2017 That is some cutting. Looks great and I love the base you found. Marg Quote
