Lawson, I've never used one on scroll saw blades, but I've used them on bandsaw blades. They do a descent job as long as you use them often enough, but on scroll work I'd be afraid of them staining the wood. They may not, but I do mostly fretwork and wouldn't chance it. The one I have is kind of purple in color in the tube, but when applied it seems to be clear.
Len
Mike Moorlach registered and sold the "Flying Dutchman" blades that he bought from Niqua in Germany.  He had a good friend that worked for 3M (world wide manufacturer of all kinds of tape including Scotch Tape).  He was told by this friend that the glue in painters tape provided the lubricant for saw blades.  I would rather doubt that there is enough to lubricate a table saw blade, but I can see where there would be enough for a scroll saw blade.  Nuff said on my part.
On 10/8/2017 at 5:42 PM, lawson56 said:
I have a question.Has anyone used those lubricant sticks? If so are they any good.:?I am ordering some blades and I was thinking of getting one.All the years I have scrolled I have never used one.:sad:
I could have used something cutting "Durarock"I could cut an inch and the blades was wore out .Good thing i saved old blades for a project like this.
16 hours ago, scrollerpete said:
Never used it but I always taped my projects with the packing tape, I rank test with cherry wood - brand new blade no tape = burn marks
with tape no burned marks at all.
I did a test like this with the blue painters tape and had the same results.  Made me sort of a believer in the tape acting somewhat as a lubricant.
I bought one 10 or so years ago. Like everyone else, I have most of it left, and I don't know if it does any good or not. I don't every remember to use it, and it seems like the blade wears out at about the same rate anyways. I will say that I never had any issue with it staining the wood. So it's got that going for it.
