blights69 Posted October 21, 2017 Report Posted October 21, 2017 Cut from Vinyl with #3 Olsen Spiral stack cut 3 so I have a couple spare in case someone else wants one as this one is already gone to my wife`s friend. lawson56, Scrolling Steve, cyclistjim and 2 others 5 Quote
Aggie Posted October 21, 2017 Report Posted October 21, 2017 Nicely done, pour me a glass blights69 1 Quote
rjR Posted October 21, 2017 Report Posted October 21, 2017 Neat! I imagine it is for the "WHINERS" too! amazingkevin and blights69 1 1 Quote
DWSUDEKUM Posted October 21, 2017 Report Posted October 21, 2017 Excellently done Frank. Do you have a pattern for that one? Thanks for sharing this with us. DW blights69 1 Quote
blights69 Posted October 21, 2017 Author Report Posted October 21, 2017 53 minutes ago, DWSUDEKUM said: Excellently done Frank. Do you have a pattern for that one? Thanks for sharing this with us. DW Have put in the library for you wombatie 1 Quote
DWSUDEKUM Posted October 21, 2017 Report Posted October 21, 2017 2 hours ago, blights69 said: Have put in the library for you Thanks Frank! blights69 1 Quote
Sam777 Posted October 21, 2017 Report Posted October 21, 2017 Nice work. How do you keep them together. We all know how to hold wood stacks. Thank you for sharing Sam blights69 1 Quote
Lucky2 Posted October 22, 2017 Report Posted October 22, 2017 Frank, that's a very nice looking clock. How do you handle the thickness offset of the clock? Len blights69 1 Quote
wombatie Posted October 22, 2017 Report Posted October 22, 2017 Wow that is terrific. Thanks for the pattern. Great work Frank. Marg blights69 1 Quote
amazingkevin Posted October 22, 2017 Report Posted October 22, 2017 13 hours ago, blights69 said: Cut from Vinyl with #3 Olsen Spiral stack cut 3 so I have a couple spare in case someone else wants one as this one is already gone to my wife`s friend. No better or worse than laser cut,You put a cnc to shame! blights69 1 Quote
lawson56 Posted October 22, 2017 Report Posted October 22, 2017 Frank,That is one Fantastic cutting. blights69 1 Quote
blights69 Posted October 22, 2017 Author Report Posted October 22, 2017 10 hours ago, Sam777 said: Nice work. How do you keep them together. We all know how to hold wood stacks. Thank you for sharing Sam Thanks Sam as in regards to keeping together to stack cut I use a very simple way and it works for me others may do different but what I do is Tape the first album but leave around 1/4" over edges I then put the other two on the rear I use a pencil through centre hole to keep them aligned I then flap the excess tape over to hold them together lightly I then stand the stack on its edge and put blue painters tape around the whole edge of the stack this seems to hold them all together no problem for me. Hope you understand what I am trying to say if not let me know I will post pictures of each stage for you. Quote
blights69 Posted October 22, 2017 Author Report Posted October 22, 2017 20 minutes ago, lawson56 said: Frank,That is one Fantastic cutting. Thanks Lawson I appreciate the positive comments lawson56 1 Quote
blights69 Posted October 22, 2017 Author Report Posted October 22, 2017 3 hours ago, amazingkevin said: No better or worse than laser cut,You put a cnc to shame! Thank you Kevin I wish the straight lines and tiny parts where as easy as a CNC sometimes Quote
blights69 Posted October 22, 2017 Author Report Posted October 22, 2017 4 hours ago, wombatie said: Wow that is terrific. Thanks for the pattern. Great work Frank. Marg No problem Marg hope it comes in handy to you at some point wombatie 1 Quote
blights69 Posted October 22, 2017 Author Report Posted October 22, 2017 5 hours ago, Lucky2 said: Frank, that's a very nice looking clock. How do you handle the thickness offset of the clock? Len Thanks Len I use 2 clocks parts I find the 3mm centre spindle are just about okay for a single album but the 8mm are needed if you use another album as the backer I have come unstuck with a 3mm before on a old thicker album so will now be using the 8mm all the time, as far as the thicness of the clock I have not had a problem with this yet I have a hanging screw in my little shop I affix the the movement loosely on the album and hang it make sure it hangs level then tweak it up. The hands I spray myself black a lot cheaper that way I do sometime times find the digital movement will move slightly no matter how much you tighten with the front nut which does make the clock slip and go un level at times I always check now and if it moves at all a few drops of what I call 2 part glue on the corners stops the movement no problems, mitre glue you may know it as basically a glue and spray activator instant bond. I find the thickness of the movement holds the clock off the wall enough when it is a single album to be able to get a nice shading behind the cut out onto the wall. Hope this kinda answers what you was asking . If I am not using a printed clock face and cutting numbers or sticking numbers on the outer edge I will use the longer arms all I get from ebay. Quote
blights69 Posted October 22, 2017 Author Report Posted October 22, 2017 12 hours ago, DWSUDEKUM said: Thanks Frank! Your welcome hope it comes in handy at some point Quote
blights69 Posted October 22, 2017 Author Report Posted October 22, 2017 16 hours ago, rjR said: Neat! I imagine it is for the "WHINERS" too! Wish it was plenty of them around here especially when I need to do the annual chainsawing of the logs for the fire, I myself like the hum of a chainsaw and the smell of fresh shavings but each to their own I suppose. Quote
blights69 Posted October 22, 2017 Author Report Posted October 22, 2017 16 hours ago, Aggie said: Nicely done, pour me a glass Thanks Terry this glass is never empty it needs only one pour then you are off Quote
Dave Monk Posted October 23, 2017 Report Posted October 23, 2017 Very cool Frank Nice pattern. blights69 1 Quote
newfie Posted October 24, 2017 Report Posted October 24, 2017 Cool piece that's something I'm sure my sister would love. Thanks for sharing blights69 1 Quote
GPscroller Posted October 24, 2017 Report Posted October 24, 2017 Really nice project Frank. Jeff Quote
