Runa Posted October 23, 2017 Report Posted October 23, 2017 How do you drill out the circles for the ornaments? Do you scroll it or use something else? Quote
kmmcrafts Posted October 23, 2017 Report Posted October 23, 2017 I do both.. just depends on the situation... It's quicker and easier to just drill them.. but.. you need a nice sharp drill bit or it can tear out.. also drill into another piece of wood to help from tear out on the last one.. I probably just saw the majority of them simply because it takes time to set up the drill press for drill the hole.. then set it back up to drill pilot holes etc.. The holes I really like are the oval shaped ones from the ornaments I've designed myself.. this way it's a bigger hole and I don't feel it's as noticeable if it's not a perfect circle LOL.. At any rate.. make them however works best for you.. Scrolling Steve, Sam777 and SCROLLSAW703 3 Quote
Phantom Scroller Posted October 23, 2017 Report Posted October 23, 2017 It depends on the size of holes big holes bigger than 1/2 " I cut on scrollsaw. Roly SCROLLSAW703 1 Quote
banderson Posted October 23, 2017 Report Posted October 23, 2017 I drill anything less than a 3/8" and a circle. It is faster and I don't have to thread the blade. SCROLLSAW703 1 Quote
WayneMahler Posted October 23, 2017 Report Posted October 23, 2017 Depends on the size of the hole. Smaller ones I drill like less then 1/8". Using a backer board and sharp clean but is great sound advice. Most of them though I cut out. SCROLLSAW703 and Scrolling Steve 2 Quote
bandaideman Posted October 23, 2017 Report Posted October 23, 2017 small holes I do with drill 1/8 inch use scrap backer for tear out. others with blade Quote
MrsN Posted October 23, 2017 Report Posted October 23, 2017 I typically cut anything bigger than 1/8". You will find the balance between the time you take to find and install a drill bit and the time it takes to install the blade and cut the hole. On some patterns (like these ornaments from Sheila Landry http://www.sheilalandrydesigns.com/product/SLD521) I want all the holes exact, I would drill. Quote
amazingkevin Posted October 24, 2017 Report Posted October 24, 2017 all good answers .it depends if im feeling lazy and need short cuts Quote
Lucky2 Posted October 24, 2017 Report Posted October 24, 2017 If it's round and I have the drill-bit that size, then I drill it. Len NC Scroller 1 Quote
lawson56 Posted October 24, 2017 Report Posted October 24, 2017 I,m like the rest,Depending on the size. Sometimes I cut,sometimes I drill. Quote
Frank Pellow Posted October 24, 2017 Report Posted October 24, 2017 Almost always, I drill such holes. Quote
