2024 Custom Ornament Business Kit - Now Available - SALE 50% Off Through Dec. 2nd ×
Any experience with this?
Kragax
I have not cut copper but have cut my share of brass. Copper could be a bit more gummier when cut. At least that is what I found when I turned it on a lathe as compared to brass. Here is a project that required cutting of brass. I used Jewelers blades to make the cuts and placed blue masking tape on the top and placed a thin wood on the bottom or else the cuts would scratch the table top too much. No need to sandwich it. Good luck.
Kragax, if you sandwich it between two layers of MDF or plywood, you can cut it with almost any blade you want to use. I wouldn't use an upcut type of blade, but any other type should be fine. As long as the copper is thin, you shouldn't have any issues. If you're worried about wasting or ruining the copper, why not try some trial and error?
Len
A few others have given good advice. Whenever I have cut metal sheets I always sandwich the metal between two pieces of 1/8 or 1/4" plywood. The sandwich keeps the pieces of metal from bending and getting caught in the blade. It also gives you something to hold on to that isn't too hot.
Give it a go and see what happens.
I did one scrolled project about 15 years ago, two carriage lamps for the garage. Made these from scratch. The flower silhouette is thin copper sheet.  As others have noted it works best to sandwich the material between two thin sheets of pw or mdf. No idea what blade I used, but it went fine. Especially important id Merlin's question, what thickness are thinking of working with.
