Scrappile Posted November 15, 2017 Report Posted November 15, 2017 How do you hid a 1/16" hole?! That is a big hole in scrolling. Jim Finn 1 Quote
Gordster Posted November 15, 2017 Report Posted November 15, 2017 Very beautiful work Jim Question..with table titled to the left,do you make cuts clockwise or anti clockwise? Jim Finn 1 Quote
Jim Finn Posted November 16, 2017 Author Report Posted November 16, 2017 2 hours ago, Gordster said: Very beautiful work Jim Question..with table titled to the left,do you make cuts clockwise or anti clockwise? Clockwise or counterclockwise gets too confusing. I keep it simple. With table tilted up on the right, and the wood to be inlaid into the base wood, on the bottom, I just keep the image or lettering to the right of the blade. Sounds simple huh? lol well it is, once you get used to it. don watson, Gordster and Karl S 2 1 Quote
Gonzo Posted November 16, 2017 Report Posted November 16, 2017 I have to agree with everyone. Beautiful work! I too would like to give inlay a try. Jim Finn 1 Quote
Jim Finn Posted November 16, 2017 Author Report Posted November 16, 2017 Yes 1/16" hole is large, but because I am using #5 blades tilted at a 2.2 degrees the hole must be larger than the blade. I drill this 1/16" hole with a mini drill press and a dremel type rotary tool at 6.6 degrees. I drill the hole just inside the pattern and it then comes out of the upper wood just outside the lower wood , in the waste part. This hole does occasionally show up a little, so before gluing the inlay in place, I sand off this hole and after glueing it in place and sanding it I fill that slight gap, and any others with a mixture of sanding powder (not sawdust, it is way too coarse) and white glue and squeege it into the voids using a credit or gift card. Karl S and don watson 2 Quote
Jim Finn Posted November 16, 2017 Author Report Posted November 16, 2017 (edited) On 11/13/2017 at 10:59 AM, Sam777 said: Awesome work Jim, How thick is the wood you used here? Thank you for sharing Sam Thank you for all the kind comments; All my boxes and inlays are made using 3/8" wood. I resaw this myself from rough boards. Any thickness will work but then all the angles change so I just always use 3/8" wood. I use 3/8" because almost all my boxes are made using cedar and cedar is a weak wood. Planing cedar thinner than 3/8" often tears the wood to pieces so I stick to 3/8" even when using walnut . I have a Hegner dedicated to doing inlay so I keep that saw angle set for inlay. I have another saw for straight through cuts, on other items, like toy making. Edited November 16, 2017 by Jim Finn Karl S and don watson 2 Quote
amazingkevin Posted November 16, 2017 Report Posted November 16, 2017 On 11/12/2017 at 6:46 PM, Rockytime said: Simply gorgeous. Wish I could do that. LOL,be careful what you wish,it can happen Jim Finn 1 Quote
amazingkevin Posted November 16, 2017 Report Posted November 16, 2017 5 hours ago, Jim Finn said: Thank you for all the kind comments; All my boxes and inlays are made using 3/8" wood. I resaw this myself from rough boards. Any thickness will work but then all the angles change so I just always use 3/8" wood. I use 3/8" because almost all my boxes are made using cedar and cedar is a weak wood. Planing cedar thinner than 3/8" often tears the wood to pieces so I stick to 3/8" even when using walnut . I have a Hegner dedicated to doing inlay so I keep that saw angle set for inlay. I have another saw for straight through cuts, on other items, like toy making. Always a joy to see your work Jim ! Jim Finn 1 Quote
don watson Posted November 16, 2017 Report Posted November 16, 2017 Fantastic piece of work. Thanks for showing and explaining your methods. Don W Jim Finn 1 Quote
Wilson's Woodworking Posted November 17, 2017 Report Posted November 17, 2017 Just as I remember. Excellent work. Jim Finn 1 Quote
GPscroller Posted November 18, 2017 Report Posted November 18, 2017 Beautiful work and thanks for the tips. Jeff Jim Finn 1 Quote
Phantom Scroller Posted November 18, 2017 Report Posted November 18, 2017 Jim you are the Master obi-wan of the inlay fantastic work. Roly Jim Finn 1 Quote
smitty0312 Posted November 18, 2017 Report Posted November 18, 2017 You're the box master Jim!! Jim Finn 1 Quote
