Popular Post olddust1 Posted November 14, 2017 Popular Post Report Posted November 14, 2017 This is a Steve Good pattern. I dark stained one for the backer. The hardest part was drilling pilot holes in the middle of the pattern. I had to use a Dremmel plunger. John Old Dust HINT: If you have to cut an oversized pattern that does not fit on your saw table try this. I had to put my blade in backwards and do some cutting that way. Itg works. Phantom Scroller, jollyred, Falcon and 12 others 15 Quote
Scrappile Posted November 14, 2017 Report Posted November 14, 2017 Well you did a fine job on it. I have never tried to cut with the blade backwards, that would seem to be a little tricky. I just switch to spiral blades for the big pieces. Quote
penquin Posted November 14, 2017 Report Posted November 14, 2017 Looks great, like the dark backer. Thanks for showing it to us. jim penquin Quote
Sam777 Posted November 14, 2017 Report Posted November 14, 2017 Very nice work indeed. Thank you for sharing Sam Quote
Rockytime Posted November 14, 2017 Report Posted November 14, 2017 Very nice cutting. Cutting in reverse...remarkable. Quote
Brianr24 Posted November 14, 2017 Report Posted November 14, 2017 Excellent job! How large is that that it didn't fit on saw? Hard to tell in photo. Quote
Gordster Posted November 14, 2017 Report Posted November 14, 2017 That turned out great John.the dark stain gives it a real west look. Thanks for the tip.I make a lot of signs that are 18 inches long and my saw is a 16. That tip may take away some tight cuts. .thank you kindly. Quote
dgman Posted November 15, 2017 Report Posted November 15, 2017 Great project John! I wasn't impressed when I saw the pattern on Steve's blog, but yours came out great! Quote
Lucky2 Posted November 15, 2017 Report Posted November 15, 2017 John, it may have been a battle to get this cut out, but from the looks of it, I'd say it was well worth the effort. Len Quote
blights69 Posted November 15, 2017 Report Posted November 15, 2017 Great job John Thanks for showing us Quote
rjR Posted November 15, 2017 Report Posted November 15, 2017 Neatly done. Heppner Guy has some of those cut too on a smaller size. Dick also did a fine job. Quote
bobscroll Posted November 15, 2017 Report Posted November 15, 2017 You did a really neat job on scrolling out your work John! Thank you for the photo, Bob Quote
wombatie Posted November 16, 2017 Report Posted November 16, 2017 Excellent work John and thanks for the tip. Marg Quote
rdatelle Posted November 16, 2017 Report Posted November 16, 2017 John, that looks good. The dark backer brings it all out. That's a good tip, putting the blade in backwards. I have a 21 inch excal, so I haven't had that problem yet. Quote
amazingkevin Posted November 17, 2017 Report Posted November 17, 2017 On 11/14/2017 at 11:01 AM, olddust1 said: This is a Steve Good pattern. I dark stained one for the backer. The hardest part was drilling pilot holes in the middle of the pattern. I had to use a Dremmel plunger. John Old Dust HINT: If you have to cut an oversized pattern that does not fit on your saw table try this. I had to put my blade in backwards and do some cutting that way. Itg works. A cowpokesdream Quote
