don watson Posted November 27, 2017 Report Posted November 27, 2017 Hi All, Cut this one today from 1¼" square Maple. Still some errors but getting better I think. bobscroll, frankorona, Lucky2 and 2 others 5 Quote
Fab4 Posted November 27, 2017 Report Posted November 27, 2017 Hi Don: This is a great improvement from your first one Looks like you're on the right track Keep up the great work Fab4 don watson 1 Quote
bobscroll Posted November 27, 2017 Report Posted November 27, 2017 Hello Don, Yes you are definately improving! Well done! Thank you for posting, Bob don watson 1 Quote
meflick Posted November 27, 2017 Report Posted November 27, 2017 Nice work. You will soon be the master of these. Thanks for sharing. don watson 1 Quote
lawson56 Posted November 27, 2017 Report Posted November 27, 2017 Fantastic work.I wish I could do as well. don watson 1 Quote
trackman Posted November 28, 2017 Report Posted November 28, 2017 You should put the date on your first pieces and compare your work in a year. You will be surprised at how much you will improve. don watson 1 Quote
GPscroller Posted November 28, 2017 Report Posted November 28, 2017 Coming along nicely Don. Jeff don watson 1 Quote
Dave Monk Posted November 28, 2017 Report Posted November 28, 2017 Big improvement. don watson 1 Quote
newfie Posted November 28, 2017 Report Posted November 28, 2017 Nice work thanks for sharing don watson 1 Quote
Lucky2 Posted November 28, 2017 Report Posted November 28, 2017 (edited) Looking good Don, your really catching on to theses things. May |I make a small suggestion though? If you made them a bit longer, you could round the ends over. And with yours being made so short, someone will try to push in on the end and cause the wood to break away. That's why I started rounding the ends over, I had one that had got broken when done like yours are. But not since I started rounding the ends over, since then none have been broken. Don, when I say rounding the ends over, I mean that I cut the ends in the shape of a semi-circle. Len Edited November 28, 2017 by Lucky2 don watson 1 Quote
wombatie Posted November 29, 2017 Report Posted November 29, 2017 A definite improvement. Looks great, well done. Marg don watson 1 Quote
amazingkevin Posted November 29, 2017 Report Posted November 29, 2017 On 11/27/2017 at 2:08 PM, don watson said: Hi All, Cut this one today from 1¼" square Maple. Still some errors but getting better I think. that's a real chip,off the ol block ! great lettering skills ,I really like this one! don watson 1 Quote
don watson Posted November 30, 2017 Author Report Posted November 30, 2017 On 28/11/2017 at 7:07 AM, Lucky2 said: Looking good Don, your really catching on to theses things. May |I make a small suggestion though? If you made them a bit longer, you could round the ends over. And with yours being made so short, someone will try to push in on the end and cause the wood to break away. That's why I started rounding the ends over, I had one that had got broken when done like yours are. But not since I started rounding the ends over, since then none have been broken. Don, when I say rounding the ends over, I mean that I cut the ends in the shape of a semi-circle. Len Thanks for that Lucky2. That is the next improvement I will make. Don W Quote
