First project with cherry, will not be the last. I like the way it cuts. Now what? If it were you, what type of finish would you use?
I am cutting a second one  -  one for my mother and the other for my mother-in-law.
Any suggestions would be greatly appreciated.
I use quite a bit of cherry in many different types of projects. Crosses, napkin holders, dream catchers, etc. I cut my own feathers for the dream catchers from cherry, too. The best way I've found is a couple couple coats of clear shellac, & then I use Watco clear gloss. On the small projects, I use a rattle can. On bigger projects, I use my air sprayer.
For something like this I would use Watco Natural Danish Oil.  All of the small areas are difficult to get in.  I sometimes put a piece in a Ziploc bag with the Danish oil and shake it a bit.  You can the pour an remaining find ish back in the container.
I also use Shellac or Poly.  If you use light coats you can avoid the plastic look.
