A couple of days ago, I posted a picture of a couple of mini Reindeer that were about 7/8" tall.  I wondered if I could make some a bit smaller.
This is the result with two smaller being 5/8" and the smallest at 7/16".  This is the smallest that I can cut.
5a25898baa26d_20171203_Mini7_16(Medium).thumb.jpg.d07d14ea6079f1a495800743af892e84.jpg
The larger Reindeer were cut from Sycamore and the smaller from Maple.  I found the Sycamore was not strong enough for making the small Reindeer.  The small ones were cut using a FD #2/0 blade.  The pictures below show the setup on my Hegner saw with the lighted magnifying glass.  I built a spring jig to hold the small blank and it has sand paper on the inside of the saws to hold the blank tight.  The springs allow a tight hold that does not change the pressure as you make the cuts.
5a2588613b2e6_20171203_MiniSaw(Medium).thumb.jpg.6e49f716ff96b5ee46fd017916a00d5c.jpg
5a25884546ad2_20171204_SaawBlank(Medium).thumb.jpg.7a82240e5ecbdd1b8cad07ba5d1a3b72.jpg
You've done the impossible,Look great too! thanks for showing your talent!
