danny Posted December 6, 2017 Report Posted December 6, 2017 Hello to All.... Having thoughts of investing in another way of controlling the Dust. Question is....Has any of you used this set up sold at SEYCO. #DV-10A Cyclonic Action Scroll Saw Dust Collector $155.00 Just looking for Pros and Cons at present. AND....I give Thanks for your Input..............Danny :+} amazingkevin 1 Quote
kmmcrafts Posted December 6, 2017 Report Posted December 6, 2017 I've been meaning to ask these same questions.. and I'll add another question.. how easy would this unit move from one saw to the next? Since I have 5 saws now, LOL but in reality I only use one at a time .. no really out of the 5 I only intend to use / keep 3 of the saws.. Wish I could figure a way out to use two at a time.. I mean.. I've got two hands and two eyes.. shouldn't be that hard to do.. Thinking in my situation maybe I should look into a Festool vac.. and pipe it to the saws with a shutoff valve or just unhook hose from one saw to the next.. amazingkevin 1 Quote
Sycamore67 Posted December 6, 2017 Report Posted December 6, 2017 I use a Festool vac with pickups above and below the table. However, it is quite a bit more expensive but more versatile as I use it for other shop tools like sander and circular saw. This unit at Seyco is about $165 and supposed to be quiet. It looks pretty good but would be better if it also collected dust above the table. OCtoolguy 1 Quote
Scrappile Posted December 6, 2017 Report Posted December 6, 2017 I didn't notice the on collection on the top, which means the dust created on top is just blown into the air. I think that is where the most you breath is generated. Unless you could modify it to suck the top dust also, I would pass. Just my opinion. Other than that, I like what I see. OCtoolguy 1 Quote
Scrolling Steve Posted December 6, 2017 Report Posted December 6, 2017 I have the system and am very pleased with the way it performs. ....This unit is quite and most of the dust is captured in the cyclone jar.....I have used it for several months and have only changed the small bag in the vac-unit once, while dumping the jar many times...I also have a 20x20 box fan near the saw with air filter taped to it.....I also have the shop vac air cleaner near by that pulls the finer dust from the shop.....Just my two cents....works for me. amazingkevin, OCtoolguy and oldhudson 3 Quote
poupster2 Posted December 6, 2017 Report Posted December 6, 2017 (edited) I just added this dust collector and I really like it. The VAC is quieter then my shop vac but still not as quiet as I would have expected. I'll be trying to fit some sort of "muffler" to the exhaust. The cyclone is absolutely awesome!!! There is barely any dust that goes to the filter. The dust collect only attaches to the bottom of the saw via a magnet. it does a decent job but it needs improvement on that one. there is no top dust collection. Seyco does supply a goose neck attachment for the top but you need to figure out how to attach it and how to connect it to the bottom hose. I plan to buy a ScrollNado and attach it to the Dust collector. Seyco also supplies a power spliter to attach to your foot switch so the VAC starts the minute you start scrolling. Overall, I'm happy with this dust collector. its not perfect but it does a very goo job at sucking up dust. Now to perfect the positioning of the hoses and that will be perfect!! Edited December 6, 2017 by poupster2 amazingkevin 1 Quote
stevan Posted December 6, 2017 Report Posted December 6, 2017 (edited) Here is what I did for above table dust removal on my Hawk. I removed the blower pipe and added a 1/2" line that connected to the main vacuum line. This new line utilizes the original hold down hardware except for the foot. I can raise and lower the line to match board thickness and the line sits almost immediately behind the blade and is close enough to vacuum anything coming off the blade or even that would sit on the work. I started with a shop vac but then transitioned to an old junked Dyson floor vacuum cleaner that was repurposed out of my neighbors garbage carrier into my dust collector. Edited December 6, 2017 by stevan amazingkevin 1 Quote
Sycamore67 Posted December 6, 2017 Report Posted December 6, 2017 Using Loc Line is also very good a top vacuum line and is easy to reposition. The consideration is also how much vacuum you pull thru a small hose. amazingkevin 1 Quote
danny Posted December 6, 2017 Author Report Posted December 6, 2017 Want to Thank ALL for your thoughts. Many that make me feel this will be Good. I like the added line running to the Blade. Looks like a Simple modification. But like was mentioned will the Vacuum have enough suction for TWO hoses. Seems like from what I read it will. I will check back here and Hope for more posts on this. Danny :+} Quote
stevan Posted December 6, 2017 Report Posted December 6, 2017 1 hour ago, danny said: Want to Thank ALL for your thoughts. Many that make me feel this will be Good. I like the added line running to the Blade. Looks like a Simple modification. But like was mentioned will the Vacuum have enough suction for TWO hoses. Seems like from what I read it will. I will check back here and Hope for more posts on this. Danny :+} A good shop vac should have sufficient vacuum to pull through two hoses. Something like 3/4" pvc as the main line should work and then your table top line would be something smaller and more flexible and easy to maneuver. amazingkevin and OCtoolguy 2 Quote
Sycamore67 Posted December 7, 2017 Report Posted December 7, 2017 I would match the main line with the size of the vacuum. Otherwise, you start choking off the flow too early. OCtoolguy and amazingkevin 2 Quote
amazingkevin Posted December 10, 2017 Report Posted December 10, 2017 All great working ideas,I've never had a vacuum yet Quote
Runa Posted December 11, 2017 Report Posted December 11, 2017 I have had huge breathing problems since i started scrolling. Both my asthma and allergies kick in a big way. I currently wear mask and eye glass and also clean my space out on a regular basis. I wish there was an economical way to collect it. I cannot imagine if my shop was i doors how i'd keep dust off. Quote
OCtoolguy Posted December 16, 2017 Report Posted December 16, 2017 (edited) I just finished my vac system for my Dewalt 788. Here are some pics. Nothing fancy but very functional. This is also in answer to the OP's question. The Dust Deputy works great. So far, it has caught almost all the sawdust. Don't look at all the other crap. My shop is a work in progress. And before anybody mentions it, I haven't tried tilting the table yet. That may require some minor adjustments. Ray Edited December 17, 2017 by octoolguy Sam777, Scrappile, Sycamore67 and 3 others 5 1 Quote
Rockytime Posted December 16, 2017 Report Posted December 16, 2017 Your system is looking good Ray. OCtoolguy 1 Quote
OCtoolguy Posted December 16, 2017 Report Posted December 16, 2017 (edited) 3 minutes ago, Rockytime said: Your system is looking good Ray. Thanks. I think it's going to be the answer to the problem of sawdust under the saw. It was only a few bucks too. Of course, I got a heck of a deal on the used Fein on Craigslist. I also discovered that the air blower is reversible so I was able to move it out of the way. Ray Edited December 16, 2017 by octoolguy Quote
stevan Posted December 16, 2017 Report Posted December 16, 2017 I think the major is expense is the vacuum. I started with my old shop vac but then found an old Dyson vacuum on the curb for garbage pick up (so I picked it up and repurposed it). OCtoolguy and Sam777 2 Quote
OCtoolguy Posted December 17, 2017 Report Posted December 17, 2017 I try to check C/L every day if I remember to. I'm always on the hunt for the many things that I still want but refuse to pay full price for. If a deal comes along on a different brand of saw that sounds too good to pass up and is within an hours drive, I'll try to get it. Ray Quote
Sycamore67 Posted December 17, 2017 Report Posted December 17, 2017 This is a great thread and catching dust at the source is the best. I have had a system like octoolguy for several years. I like the idea of running the loc line underneath the arm of my Hegner and probably will give that a try. OCtoolguy and danny 2 Quote
