qlty Posted July 23, 2010 Report Posted July 23, 2010 All the filler I've made with saw dust and glue hasn't taken stain very well it always resists the stain and does not result in a good finish match of the wood.Is there a special glue out there to use for better results?If not whats a good wood filler on the market and how do you use it?Perhaps pre staining the filler before applying It ?? Quote
Kepy Posted July 23, 2010 Report Posted July 23, 2010 I've seen a wood glue that claims to be stainable (maybe Elmer's). Quote
wdkits1 Posted July 23, 2010 Report Posted July 23, 2010 I use white glue mixed with fine sawdust for use when filling small cracks if the wood is to be kept natural color. If the wood is to be stained I use the same procedure before staining but then I sand it down after the filler is dry then mix a little stain with wipe on satin poly and using a foam brush dab it on to cover the filled area. Once the poly is dry it can be sanded and re-applied if necessary. I do this when repairing furniture where I'm trying to match the original color. Works great. Quote
Vector01 Posted July 23, 2010 Report Posted July 23, 2010 When I used to repair gun stocks, I used Elmers white glue and mix some sandings from the gun stock. This worked great for small cracks and dings I couldn't raise with a damp cloth and an iron. If the area is large maybe some wood filler would work. Quote
