hotshot Posted December 20, 2017 Report Posted December 20, 2017 (edited) I've told people that the blades I used are as small as a regular sewing pin, but both are so small, it's kind of hard to know for sure without really really zooming in. So out of curiosity, I scanned the smallest blade I commonly use. I assumed I would get a profile view, but was thrilled to see the front which give an idea of the actual kerf. I can't really see the teeth with the naked eye, so it was nice to get a zoomed image. Anyway, I though this was really neat, hopefully you will also. Click the picture below so see full size, so you can see the teeth. Edited December 20, 2017 by hotshot OCtoolguy, New Guy, jollyred and 5 others 5 3 Quote
rjweb Posted December 20, 2017 Report Posted December 20, 2017 Wow, I know these old eyes of mine would not be able to do the beautiful work you do Randy, thx for showing, RJ OCtoolguy 1 Quote
OCtoolguy Posted December 20, 2017 Report Posted December 20, 2017 I'd love to see one of your finished works RJ. Have you got them posted anywhere? Ray Quote
Lucky2 Posted December 20, 2017 Report Posted December 20, 2017 Randy, are these the blades you use to cut coins with, where do you purchase them from? Len Quote
hotshot Posted December 20, 2017 Author Report Posted December 20, 2017 44 minutes ago, Lucky2 said: Randy, are these the blades you use to cut coins with, where do you purchase them from? Len Len, these are Pike blades and this specific size is used only when I need very small kerfs. I use 3/0 much more often. I did use this 6/0 size for the entire "Serenity Cut" that I'm getting ready to post. I usually shop Amazon for these blades. Shop around, and be careful because some vendors aren't clear on quantity. I aways look for 144 (gross) pricing. WayneMahler and Lucky2 2 Quote
lawson56 Posted December 20, 2017 Report Posted December 20, 2017 Randy,that is So Awesome!!!Love and Greatly Admire your work. Quote
OCtoolguy Posted December 20, 2017 Report Posted December 20, 2017 14 hours ago, hotshot said: Len, these are Pike blades and this specific size is used only when I need very small kerfs. I use 3/0 much more often. I did use this 6/0 size for the entire "Serenity Cut" that I'm getting ready to post. I usually shop Amazon for these blades. Shop around, and be careful because some vendors aren't clear on quantity. I aways look for 144 (gross) pricing. Randy, have you checked out Otto Frei? They specialize in watch tools. I bought a gross of 2/0 from them along with some other stuff. I'm not sure if my price was good or not but I was told to buy there from the guy who I took the class on marquetry from. Ray Quote
OCtoolguy Posted December 20, 2017 Report Posted December 20, 2017 Randy, I just found some of your work in the Gallery section. I must say, you are VERY talented. I don't see how you do it. Emphasis on the word "see". Truly beautiful work. Ray WayneMahler and hotshot 2 Quote
amazingkevin Posted December 25, 2017 Report Posted December 25, 2017 On 12/19/2017 at 7:41 PM, hotshot said: I've told people that the blades I used are as small as a regular sewing pin, but both are so small, it's kind of hard to know for sure without really really zooming in. So out of curiosity, I scanned the smallest blade I commonly use. I assumed I would get a profile view, but was thrilled to see the front which give an idea of the actual kerf. I can't really see the teeth with the naked eye, so it was nice to get a zoomed image. Anyway, I though this was really neat, hopefully you will also. Click the picture below so see full size, so you can see the teeth. nice fragile blade! Quote
JTTHECLOCKMAN Posted December 25, 2017 Report Posted December 25, 2017 (edited) http://www.ishor.com/jeweler-bench-tools/jeweler-39-s-saws-and-blades I buy my jewlers blades from here Edited December 25, 2017 by JTTHECLOCKMAN Quote
hotshot Posted December 25, 2017 Author Report Posted December 25, 2017 (edited) 19 minutes ago, JTTHECLOCKMAN said: http://www.ishor.com/jeweler-bench-tools/jeweler-39-s-saws-and-blades I buy my jewlers blades from here Which blades are you buying from there? I noticed they have the Forms d'Art blades that I started with many years ago. Not great blades overall, but I still recommend them for beginners because they are very very cheap, and they have a more metal on the backbone (shorter teeth). They are not as aggressive and do not turn as easily, so I moved on to the Pike brand which is very good (Same company that makes Pegas). There are several other brands on the site that are new and intriguing to me. I've been curious about the more expensive German blades, but they are over twice as expensive as the Pike I've been using, and I break a ton of blades, so I've been scared to try those. I might like them, then I would up a creek. :-) Edited December 25, 2017 by hotshot Quote
JTTHECLOCKMAN Posted December 26, 2017 Report Posted December 26, 2017 (edited) 8 hours ago, hotshot said: Which blades are you buying from there? I noticed they have the Forms d'Art blades that I started with many years ago. Not great blades overall, but I still recommend them for beginners because they are very very cheap, and they have a more metal on the backbone (shorter teeth). They are not as aggressive and do not turn as easily, so I moved on to the Pike brand which is very good (Same company that makes Pegas). There are several other brands on the site that are new and intriguing to me. I've been curious about the more expensive German blades, but they are over twice as expensive as the Pike I've been using, and I break a ton of blades, so I've been scared to try those. I might like them, then I would up a creek. :-) http://www.ishor.com/antelope-blue-label Great blades. Maybe a little more expensive but last a long time. I cut alot of brass with them. I do not need to go down to 6/0 so can not speak to them. 1/0 to 3/0 and #1 to #3 Never tried Pike. Trying to remember another brand I use to buy but was breaking them too fast and that is why I asked around and found these. Found an old package, they were called Mascot. Can not remember where I was buying them. I cut a quarter in half lengthwise on my Dewalt scrollsaw as a bet once and used 2 #1 antelope blades. Being you cut coins you know that metal is hard to cut. It is a mixture blend. I won the bet. Not an easy thing to do but the Dewalt was up to the task. Edited December 26, 2017 by JTTHECLOCKMAN kmmcrafts 1 Quote
amazingkevin Posted December 28, 2017 Report Posted December 28, 2017 On 12/19/2017 at 7:41 PM, hotshot said: I've told people that the blades I used are as small as a regular sewing pin, but both are so small, it's kind of hard to know for sure without really really zooming in. So out of curiosity, I scanned the smallest blade I commonly use. I assumed I would get a profile view, but was thrilled to see the front which give an idea of the actual kerf. I can't really see the teeth with the naked eye, so it was nice to get a zoomed image. Anyway, I though this was really neat, hopefully you will also. Click the picture below so see full size, so you can see the teeth. I enjoyed cutting coins,only 3 of them.So many things distract your interests here and things end up out of site out of mind! Quote
Rockytime Posted December 28, 2017 Report Posted December 28, 2017 I just found my 6/0 Pike blades which I had forgotten about. I had never used them. Out of curiosity I miked one The blade is .0085". Conversely a sheet of 50# copy paper is .004". A human hair, at least one of mine, is .0043". Tiny blades for sure. Quote
