bowers25 Posted December 24, 2017 Report Posted December 24, 2017 Need help locating a replacement or cross reference a air diaphragm & a air nozzle for a Delta 40-540 16" variable speed. Just starting out scrolling, the saw was given to me. I have cleaned up all the rust and lubed it..........runs great, but no air moves across my work piece due to a dry rotted air diaphragm. Unable to located a new or cross reference part. Thanks & Be Safe! OCtoolguy 1 Quote
jollyred Posted December 24, 2017 Report Posted December 24, 2017 Try eparts, they have parts for almost everything. Prices seem to be reasonable. They also show the blown apart machine, which is a great help in finding the part. OCtoolguy 1 Quote
bowers25 Posted December 24, 2017 Author Report Posted December 24, 2017 Roger That........I did.......no luck, every website I have visited states discontinued or out of stock. OCtoolguy 1 Quote
JustLarry Posted December 24, 2017 Report Posted December 24, 2017 Your best bet may be to get an aquarium air pump. I did this on one of my saws. Found one at resale shop for $1.00. Actually works better than the factory diaphragm did. Larry twalsh1490, OCtoolguy and danny 2 1 Quote
loftyhermes Posted December 24, 2017 Report Posted December 24, 2017 My solution to this problem was to get a dogs squeaky toy, remove the squeaker and put the pipe in the hole, then glue the squeaker under the bottom arm. stoney, JustLarry, Wilson142 and 5 others 7 1 Quote
Rockytime Posted December 24, 2017 Report Posted December 24, 2017 That's thinking out of the box. Ingenious! OCtoolguy 1 Quote
OCtoolguy Posted December 24, 2017 Report Posted December 24, 2017 20 hours ago, JustLarry said: Your best bet may be to get an aquarium air pump. I did this on one of my saws. Found one at resale shop for $1.00. Actually works better than the factory diaphragm did. Larry You beat me to it. I was going to suggest a fish tank pump. They work great. Ray Quote
crupiea Posted December 24, 2017 Report Posted December 24, 2017 I use an aquarium pump and tubing. If you saw really sow like I do the bellows are pretty much worthless. The pump is blowing a nice stream of air all the time. Cheap and works forever. OCtoolguy and twalsh1490 1 1 Quote
bowers25 Posted December 26, 2017 Author Report Posted December 26, 2017 aquarium air pump it is then.........What would be a good cfm rate to use? Thanks all for you help......Greatly Appreciated OCtoolguy 1 Quote
OCtoolguy Posted December 26, 2017 Report Posted December 26, 2017 4 hours ago, bowers25 said: aquarium air pump it is then.........What would be a good cfm rate to use? Thanks all for you help......Greatly Appreciated I would go with the smallest one. You don't need much air and they put out pretty good. Ray Quote
crupiea Posted December 27, 2017 Report Posted December 27, 2017 Should be under $10 and that includes the tubing. OCtoolguy 1 Quote
Rolf Posted December 27, 2017 Report Posted December 27, 2017 (edited) As most have said go with an air pump. Even when new the blowers on the Delta saws were pretty lame. Although the squeaky toy idea is very clever. Edited December 27, 2017 by Rolf OCtoolguy 1 Quote
amazingkevin Posted December 28, 2017 Report Posted December 28, 2017 On 12/23/2017 at 7:30 PM, bowers25 said: Need help locating a replacement or cross reference a air diaphragm & a air nozzle for a Delta 40-540 16" variable speed. Just starting out scrolling, the saw was given to me. I have cleaned up all the rust and lubed it..........runs great, but no air moves across my work piece due to a dry rotted air diaphragm. Unable to located a new or cross reference part. Thanks & Be Safe! Looks like a quick easy right now way is with an aquarium air pump,But i have that ss250 delta saw that i use for my rattle can paint shaker .I can check to see if the diagram is good and send it to you if you like. twalsh1490 and OCtoolguy 2 Quote
bowers25 Posted December 31, 2017 Author Report Posted December 31, 2017 Thanks for the offer, it's greatly appreciated.....I'm going to try the aquarium pump or maybe a bait pump and see how that works. Have a Great New Year & Be Safe! OCtoolguy 1 Quote
Tim G Posted June 1, 2023 Report Posted June 1, 2023 Years ago I saved this blood pressure hose from the trash. Dug it out and works out great. OCtoolguy 1 Quote
OCtoolguy Posted June 1, 2023 Report Posted June 1, 2023 Wow! This one came back from the dead. Quote
flarud Posted June 2, 2023 Report Posted June 2, 2023 4 hours ago, OCtoolguy said: Wow! This one came back from the dead. What threw me for a minute was seeing one of Rockytime's posts,, then I checked the date. OCtoolguy 1 Quote
OCtoolguy Posted June 2, 2023 Report Posted June 2, 2023 17 hours ago, flarud said: What threw me for a minute was seeing one of Rockytime's posts,, then I checked the date. Yes, me too. I sure do miss him. Quote
