hotshot Posted December 26, 2017 Report Posted December 26, 2017 (edited) I've been getting pinged by various folks looking at trying their hands at coin cutting. I thought I would take a minute and give a quick "Secrets" type post. In this case, I want to show a technique that makes it look like your piece has floaters, while in truth, the supports are hidden. Let me show you: I want to draw attention to the section circled below: In the unobstructed image below, it look like that piece is "Floating" with no supports. This technique is common amongst the better coin cutters. So what is going on? The surface material over the supports has been cut away, hiding the supports further below the surface. If you look carefully, you can see the supports buried down underneath. So, how is the surface cut away? Believe it or not, it is possible to cut while holding one edge of the coin up at an angle. If you cut from both sides, you will be left with a wedge as your support, but no surface material. This does weaken the support, so I have to be careful not to remove too much. Does this look a little awkward? It is a little, but the hard part is seeing what I am cutting with the coin angled up away from me. I have to lean way forward. In the past, I have also turned the blade around backwards so I can cut with the face of the coin facing me. Well, I wanted to show you something different, I hope I did :-) -----Randy Edited December 26, 2017 by hotshot NC Scroller, crupiea, stoney and 6 others 6 3 Quote
Dave Monk Posted December 26, 2017 Report Posted December 26, 2017 That is totally crazy Randy. hotshot 1 Quote
spirithorse Posted December 26, 2017 Report Posted December 26, 2017 Pretty cool stuff, Randy! I don't know that I am ready to try that with wood yet but, you certainly have me thinking! Thanks for sharing and God Bless! Spirithorse Quote
WayneMahler Posted December 26, 2017 Report Posted December 26, 2017 Nice to know this technique for coins. Got me wondering if it would work with wood. But I guess that would depend on the wood too. Thanks for sharing this Randy. Quote
OCtoolguy Posted December 27, 2017 Report Posted December 27, 2017 1 hour ago, hotshot said: I've been getting pinged by various folks looking at trying their hands at coin cutting. I thought I would take a minute and give a quick "Secrets" type post. In this case, I want to show a technique that makes it look like your piece has floaters, while in truth, the supports are hidden. Let me show you: I want to draw attention to the section circled below: In the unobstructed image below, it look like that piece is "Floating" with no supports. This technique is common amongst the better coin cutters. So what is going on? The surface material over the supports has been cut away, hiding the supports further below the surface. If you look carefully, you can see the supports buried down underneath. So, how is the surface cut away? Believe it or not, it is possible to cut while holding one edge of the coin up at an angle. If you cut from both sides, you will be left with a wedge as your support, but no surface material. This does weaken the support, so I have to be careful not to remove too much. Does this look a little awkward? It is a little, but the hard part is seeing what I am cutting with the coin angled up away from me. I have to lean way forward. In the past, I have also turned the blade around backwards so I can cut with the face of the coin facing me. Well, I wanted to show you something different, I hope I did :-) -----Randy I'm curious Randy. What cutting speed do you use? Ray Quote
Scrappile Posted December 27, 2017 Report Posted December 27, 2017 Holy Cow!! That is some advanced cutting for sure. Quote
hotshot Posted December 27, 2017 Author Report Posted December 27, 2017 (edited) 5 hours ago, octoolguy said: I'm curious Randy. What cutting speed do you use? Ray On the Ex, I'm probably running at about 3/4. I can't run slow or the blade will catch on turns. Edited December 27, 2017 by hotshot OCtoolguy 1 Quote
rjweb Posted December 27, 2017 Report Posted December 27, 2017 Randy thx for sharing, but for now I will stay with wood, RJ OCtoolguy 1 Quote
amazingkevin Posted December 28, 2017 Report Posted December 28, 2017 On 12/26/2017 at 5:35 PM, hotshot said: I've been getting pinged by various folks looking at trying their hands at coin cutting. I thought I would take a minute and give a quick "Secrets" type post. In this case, I want to show a technique that makes it look like your piece has floaters, while in truth, the supports are hidden. Let me show you: I want to draw attention to the section circled below: In the unobstructed image below, it look like that piece is "Floating" with no supports. This technique is common amongst the better coin cutters. So what is going on? The surface material over the supports has been cut away, hiding the supports further below the surface. If you look carefully, you can see the supports buried down underneath. So, how is the surface cut away? Believe it or not, it is possible to cut while holding one edge of the coin up at an angle. If you cut from both sides, you will be left with a wedge as your support, but no surface material. This does weaken the support, so I have to be careful not to remove too much. Does this look a little awkward? It is a little, but the hard part is seeing what I am cutting with the coin angled up away from me. I have to lean way forward. In the past, I have also turned the blade around backwards so I can cut with the face of the coin facing me. Well, I wanted to show you something different, I hope I did :-) -----Randy Yes you certainly let the cat out of the bag,Thanks!!!!!!!!!! Quote
Lucky2 Posted December 30, 2017 Report Posted December 30, 2017 Randy, couldn't you use a Dremel tool, with a small cutting wheel to do this? Len Quote
