blights69 Posted December 31, 2017 Report Posted December 31, 2017 Had a request for a vinyl clock Elvis related so stack cut 3 turned 1 into the clock and have the other 2 I can keep as pictures or turn into another clock if needed, cut with everybody`s favourite a spiral Now to clear up the vinyl chippings and make some dust on a Sunday what better way to spend it MTCowpoke22, lawson56, Phantom Scroller and 6 others 9 Quote
Scrolling Steve Posted December 31, 2017 Report Posted December 31, 2017 Nice work Frank ! blights69 1 Quote
rdatelle Posted December 31, 2017 Report Posted December 31, 2017 Those look great Frank. Is there any tips on how to cut vinyl records. What size blade can you use besides spiral and do you sandwich them between wood like I do with plexiglass. I would love to do some of these with Elvis for a good friend of mine whose a big elvis fan. blights69 1 Quote
blights69 Posted December 31, 2017 Author Report Posted December 31, 2017 1 hour ago, rdatelle said: Those look great Frank. Is there any tips on how to cut vinyl records. What size blade can you use besides spiral and do you sandwich them between wood like I do with plexiglass. I would love to do some of these with Elvis for a good friend of mine whose a big elvis fan. I would of thought you could use any size blade if you sandwich the vinyl between wood I have not tried that with vinyl yet but I have done as you have with plexiglass so should also work with vinyl not sure whether the cut line would melt back in on the vinyl though that may be an issue with a normal blade I know someone else who gave it a go on vinyl with a spiral had trouble with the cut line melting back in and had a job of cleaning up after I have only had that happen a few times and always when it is a small slow cutting part the faster I cut the less it happens on vinyl but I am going to give the sandwich a go see what happens and if nothing else I will end up with 2 pictures in wood even if the vinyl in the middle fails Quote
rdatelle Posted December 31, 2017 Report Posted December 31, 2017 That is the upside Frank. You end up with two of the same picture in wood. blights69 1 Quote
DWSUDEKUM Posted December 31, 2017 Report Posted December 31, 2017 Very nicely done Frank. Thanks for sharing this with us. DW blights69 1 Quote
GPscroller Posted December 31, 2017 Report Posted December 31, 2017 Looks great Frank. Jeff blights69 1 Quote
lawson56 Posted December 31, 2017 Report Posted December 31, 2017 Frank,They look,Super Fantastic!! blights69 1 Quote
spirithorse Posted December 31, 2017 Report Posted December 31, 2017 Great work! Thanks for sharing and God Bless! Spirithorse blights69 1 Quote
amazingkevin Posted January 1, 2018 Report Posted January 1, 2018 9 hours ago, blights69 said: I would of thought you could use any size blade if you sandwich the vinyl between wood I have not tried that with vinyl yet but I have done as you have with plexiglass so should also work with vinyl not sure whether the cut line would melt back in on the vinyl though that may be an issue with a normal blade I know someone else who gave it a go on vinyl with a spiral had trouble with the cut line melting back in and had a job of cleaning up after I have only had that happen a few times and always when it is a small slow cutting part the faster I cut the less it happens on vinyl but I am going to give the sandwich a go see what happens and if nothing else I will end up with 2 pictures in wood even if the vinyl in the middle fails You've gone where no man's gone before.Love your cuts in vinyl! blights69 1 Quote
wombatie Posted January 1, 2018 Report Posted January 1, 2018 Fabulous. Great work once again Frank. Marg blights69 1 Quote
Lucky2 Posted January 1, 2018 Report Posted January 1, 2018 Nicely done Frank, do you paint the albums, why do they not look black? Len blights69 1 Quote
blights69 Posted January 1, 2018 Author Report Posted January 1, 2018 7 hours ago, amazingkevin said: You've gone where no man's gone before.Love your cuts in vinyl! Thank you Kevin it is nice to get positive comments from yourself and others on here on the vinyl pieces I cut, I know some do not like them as it is not wood but I like to try cutting different things as I learn more and I always leave some saw dust on my floor to remind me to go back to wood Quote
blights69 Posted January 1, 2018 Author Report Posted January 1, 2018 2 hours ago, Lucky2 said: Nicely done Frank, do you paint the albums, why do they not look black? Len I leave some as they are and spray the backer a different colour to allow it to stand out and some I spray with pound shop cans no expense spared here Len Quote
newfie Posted January 3, 2018 Report Posted January 3, 2018 Nice work thanks for sharing blights69 1 Quote
