Brianr24 Posted January 6, 2018 Report Posted January 6, 2018 Pattern is In library from bigdogskitten11 lol. I don't like painting background board black on these type of projects. Iv been putting walnut veneer on luan and oiling it. I'm not sure it's worth the effort tho when u don't see much of it. I'm experimenting with a technique to try veneer front of basswood boards. I'm thinking of using the dato blade to take just the thickness of veneer off up to the bark area. Will be tricky and again not sure if worth effort.well sorry about the long post. lawson56, jollyred, frankorona and 3 others 6 Quote
Lucky2 Posted January 6, 2018 Report Posted January 6, 2018 Brian, it looks good with the walnut backer, but I really do like a black backer. And if your making these to sell, your adding a lot of extra work to the project. Spray painting a backer is so simple and quick, and there's very little labor involved. Len Quote
DWSUDEKUM Posted January 6, 2018 Report Posted January 6, 2018 Brian nice work first of all. Here is another idea. This idea is an off shoot of your router usage. Route out the area(s) that you want to have some color in and flock that area.. especially the deer body. This should give it depth and texture as well as color. Thanks for sharing this with us. DW amazingkevin 1 Quote
penquin Posted January 6, 2018 Report Posted January 6, 2018 Nice work, looks great. Thanks for showing it to us. jim penquin Quote
fredfret Posted January 7, 2018 Report Posted January 7, 2018 Black felt as or on the backer is what I do. I prefer black for most projects. Like in the attached Fred fret Wichita, ks amazingkevin and lawson56 2 Quote
amazingkevin Posted January 7, 2018 Report Posted January 7, 2018 6 hours ago, Brianr24 said: Pattern is In library from bigdogskitten11 lol. I don't like painting background board black on these type of projects. Iv been putting walnut veneer on luan and oiling it. I'm not sure it's worth the effort tho when u don't see much of it. I'm experimenting with a technique to try veneer front of basswood boards. I'm thinking of using the dato blade to take just the thickness of veneer off up to the bark area. Will be tricky and again not sure if worth effort.well sorry about the long post. What ever you chose will more than sufficient!Nice cutting skills!!!!!!!!! Quote
wombatie Posted January 7, 2018 Report Posted January 7, 2018 Whatever you choose, you do great work. Marg Quote
lawson56 Posted January 7, 2018 Report Posted January 7, 2018 Looks Fantastic..I also prefer black.but as the old saying goes,Nothing ventured nothing gained. Quote
rdatelle Posted January 7, 2018 Report Posted January 7, 2018 Brian, that looks good with the brown backer. I also use a lots of black. I have different colors of felt and that's what I usually use. Felt is pretty cheap. Quote
blights69 Posted January 7, 2018 Report Posted January 7, 2018 Great job on the cut I also use black a lot and spray my backers but I have added colours here and there too to make certain parts stand out a bit each to their own. Quote
Dave Monk Posted January 8, 2018 Report Posted January 8, 2018 Very nice. One nice thing about this site is that you get a lot of opinions to get ideas to experiment with. Quote
