I have a mouse sander that I use on my portrait style cuttings. It only vibrates just like any ol' palm sander. I like it because its not too aggressive on the real delicate parts of the cuttings. I was wondering if anybody uses a random orbital sander on these kinds of cuttings and if they've had good luck with it? I have a random orbital sander, but have always been leery of using it on delicate work.
I also have a mouse sander and random orbital. Since I bought the orbital sander my mouse has been in its case unused. I have not had any problems with the orbital. although if its turning at full speed you don't want to put it to the wood, it wil leave marks.
I too use a ROS "finishing" sander with pretty good results. Breakout has never been much of an issue -- and I cut some secenes that have upwards of 1,200 cuts. I say "finishing" sander, or pad sander, because I also have a rotating ROS that I wouldn't dare use.
One tip if you use a ROS, get yourself a sanding mat like this. Put on a flat surface, they cushion and support the piece while keeping it from moving around.
  • 5 weeks later...
