The good news is I finally got lucky and found a Hegner on E-bay UK which was offered with the Global Shipping Programme.  It is a 2014 model Multicut 2S with variable speed and the quick clamp and up front tension lever so I decided I had to have it.  The bad news it will take three weeks to get here.  However that gives me time to sort out a stand for it.  I'm not sure if the footprint is universal on all Hegners but if anyone has the same model I would appreciate measurements of the base plate so I can get started.
Thanks in advance,
Rob
Rob the saw measures 43X43 CM But of course it is on an angle.If you look at the pictures of it you will see what I mean .But if I already did not have a stand i would build the top at least 50x 50 CM .As far as the legs .What ever you are used to and comfortable with.But make it heavy to appreciate the Hegner advantages.
