Sanding mops are often recommended as a finishing tool for scroll work. I wondered if those of you who use them regularly would recommend:
a brand; size; and supplier
Are you chucking them in a drill or drill press or something else?
Thanks for reading.
I have the sanding mop and the Mac Mop from Klingspor .  The sand mops are best for curves and such and are stiffer than the mac mops.  I use the Mac Mops, mounted in my lathe and sand flat stock with them.  I have the 4" sanding mops and the 7" Mac Mops.  I use the Mac Mops the most, because I mostly do fret work.
I have the 4" mop, and use it on a used washing machine motor with a drill chuck mounted on it.  It is attached to a board and clamped to the worktable for use.  I also use a dust collector about 6" from the mop to collect the sanding dust, and a respirator.
Thanks for reading.
the small dremel ones i have i use in my battery drill,the bigger ones i make up to 4" i still use in my  battery drill.
