Hi Joe. below this box that you type in your request is a blue box. on it is a tab that says upload attachments, click on that. then click the browse button, locate the file from your computer you want to load then click add the file and it should show up in your post when you hit submit.
If you put the request in the pattern request section you may have better results. Hope this helps a little.
