So another warm night out there 33F so I went out and replaced my upgraded tension cam and the new style upper blade holder.. New bearings wasn't needed.. in fact maybe bearings was made better back in the 90's as these look like new.. good thing too.. because after taking the saw apart I find that it has a whole different style of bearing than the newer 226 Ultra has... connecting rod bearings the same.. but again wasn't needed.. She's running real nice and smooth through all the gears.. no vibration to really speak about through the whole range of speeds.. I sort of like the thrust bearing style of this older saw better than I do the newer one..
Guess now my next project will be to set up and tune the new Excalibur and when these are all done and running good.. I'll take the 788 apart for new bearings inside the case at the back of the saw.. getting a little noisy back there and still running the originals from 2008 back there..
Boy that last sentence JT.. You sure hit that one.. most everything now days is just cheap junk and when it breaks you throw it out and buy another.. well.. for most people.. I seem to like to take things apart to see if I can fix and improve on them, LOL
