Looks like my $200 Hawk will be a $350 Hawk. I pulled the controller. The pot and switch are OK. Current flow is stopped somewhere in the pc board. Tomorrow I will switch controllers with the older Hawk for a dynamic testing to see if the controller works on the older saw. That will be the final test. If it does not work on the older saw I will have to spring for a new controller. Darn!
1 hour ago, Rockytime said:
Not without a schematic. Someone with electronic experience could possibly but that's way beyond the scope of my intelligence. Many years ago, perhaps 60 or so, I used to do TV repair. I know nothing about solid state. But thanks for the suggestion.
Rocky, you don't need a schematic to test the components on the board. You can check resistors with an ohm meter. And a visual inspection of the pc board should show you if there is anything burned or cracked. Don't give up on it without at least letting someone who knows what's what to take a look at it. Exhaust all avenues before plunking down the cash. Does the saw run at all? Maybe the rocker switch is bad.
Ray
Edited by octoolguy
16 hours ago, Rockytime said:
I've looked carefully at the board and see nothing suspicious. I have not removed the board to inspect for circuit breaks. Don't think I will do that.
Rocky, I did a youtube search for how to troubleshoot that controller but found nothing. But, like someone else said, I'll bet if you took it to an electronics store someone there would be able to maybe put you in the right direction. I'll still bet it's something simple and cheap.
Ray
Rocky, I just went to this website and you might be able to buy a board from the mfgr. Give it a shot.
http://www.quantum-controls.com/standard-products/
Ray
From what you described, if nothing looks or smells burnt, it is most likely the chip. If you can get the number off the chip you can probably pick one up (or order online) for less than $10. I can point you to some reliable sources if you choose to try to repair the board. I would still call the company first as Ray suggested.
Len, I just took the picture of your controller and brought into Irfanview. I rotated it 180 and zoomed in on it to try to see more of the pieces and parts. To me, the solder joints on the potentiometer don't look good. Is there a possibility that there might be a "cold" joint on the red wire? It just doesn't look good to me. It should be a smooth shiny flow of solder and from what I can see in the pic, it doesn't look that way. I'd sure like to see the underside of that board too.
I have decided to purchase a controller. I can make much more money repairing a clock and in less time than I spend with the controller. I do appreciate the input from each one of you. What a great group. Were it a simple and quick fix I would do it. The simplest thing is a defective pot or cold solder joint but that is not the case.
Yeah solid state throws me off too.If you ever get a chance to look inside a new tv,You can't tell the power supply from a horizontal  output .It all one big board and a beautiful site to see too.
This was sure an interesting post, full of fun ideas. It was all  Greek to me but I am amazed that there are people on this site who are knowledgeable on apparently everything out there. For me this subject is as mysterious as the workings of a washing machine is to most average housewives.
Dick
heppnerguy
I watched a couple of youtube videos on how to fix our Mitsubishi and it really isn't all that hard. Just pieces and parts.
Ray
Dick
heppnerguy
I'm one of those people who absolutely hate to throw anything away if there is the remotest possibility of fixing it. My wife's washer was making a noise so I called a repair guy. He told me that we should trash it and buy a new one because it would be a minimum of $400 for him to service it. I once again went to youtube and found a video. Everything is repairable in most cases.
Ray
Ray
usually, if it isn't simple, it would not have invented.  I know that  does not cover all things, but the majority of them.. like washing machines.. It is the new electronic boards that keep me away from trying to repair most things any more...They seem to be something that is expensive to buy and unfixable for the average lay man.
Dick
heppnerguy
Dick
heppnerguy
And you would be oh so correct. But, when it comes to making a noise when it shouldn't, that is usually mechanical so fixable. We have a service contract right now that is good for one more year. Then we will let it go until we need it again. The last time we had a issue that I wasn't sure how to fix, we called the service guy out and he diagnosed the problem as the door lock interlock. Electronic and mechanical. He told us how much to fix it but at the same time, he offered to sell us a two year service plan that would cover the repair and cover us for the next two years for not much more. Well it was a no brainer to buy the plan. He fixed the problem, supplied the parts and we were covered for two years. I'm sure that the next time it happens, if we are out of contract, we'll be offered that same thing again. At that point, we will have to figure out if we want to renew or buy a new washer or pay to fix it. Whatever works.
R
R
yes sometimes it is a catch 22. Which way to go. after you put almost as much into an item and a new one would cost it becomes time to move the new,
Dick
heppnerguy
Somehow, my mom's furnace started making noise. Long story short is the plastic fan blades had broke causing vibration. It was Saturday and the local part store was closed. It was a $35 part. Mom wanted it fixed that day and ended up costing $280. I cringed!
But, you fixed it without buying a new furnace. That's the whole point.
Ray
