Problem Solved: Wen Scroll saw Pinless Adapter and inside cuts.
If you have or are thinking of purchasing a Wen scroll saw, one of the issues with it is cutting inside patterns. You have to remove one of the adapters to thread the blade through the drill hole.
When you remove the top, the bottom falls down. If you remove the bottom, it's difficult to impossible to reset the set screw to secure the blade!
It's really inconvenient and a PITA trying to get the adapters back on the holder.
Today I've solved the problem, at least for myself.
I placed a magnet on the bottom adapter to hold it in place:
Now I can undo the top adapter, let it hang free while I insert the blade into the drilled hole and then re-tighten the set screw
Now it's not nearly as difficult trying to thread the blade through a drill hole
Edited by new2woodwrk
