OCtoolguy Posted February 4, 2018 Report Posted February 4, 2018 I just tried using some of the FD UR blades and I think I like them. So far at least. I was just wondering if they are available by any other mfgr? Or something similar. Just want to explore all avenues. I think I will be buying more sizes. I got #5's in the sample pack. I was cutting some 5/16" BB and they seemed to do very well on my Dewalt saw. Ray SCROLLSAW703 1 Quote
ed martin Posted February 4, 2018 Report Posted February 4, 2018 Hear you go.https://mikesworkshop.com/ OCtoolguy and SCROLLSAW703 2 Quote
OCtoolguy Posted February 4, 2018 Author Report Posted February 4, 2018 2 minutes ago, ed martin said: Hear you go.https://mikesworkshop.com/ Thanks. That's where I got them before Mike retired. But, I was just wondering if any of the other mfgrs. made anything similar. I have looked at all the blade charts for Olson, and Pegas but so far, I don't see anything like the FD-UR blades. Ray Quote
ed martin Posted February 4, 2018 Report Posted February 4, 2018 FD-UR I get mine at mikes, Pegas modified geometry is what I just changed to they cut better and last longer, You just have to try them. http://www.dndsawbladesonline.com/page/79818204 OCtoolguy 1 Quote
JustLarry Posted February 4, 2018 Report Posted February 4, 2018 (edited) Ray, FD blades are manufactured by Niqua in Germany. The UR is my go to blade. Here are links to blade info: https://forum.scrollsawer.com/forum/scroll-saw/tools-and-blades/31121-niqua-and-flying-dutchman-blades (Post #8 was made by Mike) http://www.hawkwoodworkingtools.com/ScrollSaw/ScrollSawParts/SS_BLADE_CHART_2-22-2013.pdf (scroll down for info on FD Blades) Larry . Edited February 4, 2018 by JustLarry OCtoolguy 1 Quote
loftyhermes Posted February 4, 2018 Report Posted February 4, 2018 (edited) Niqua make one called Top Cut which is the same as FDUR (not surprising since they make FD blades) but without the little kink. Olson make one called Crown Cut which has every other tooth reversed. happy scrolling Steve Edited February 4, 2018 by loftyhermes OCtoolguy 1 Quote
ike Posted February 4, 2018 Report Posted February 4, 2018 (edited) I have tried both FD and Olson blades mentioned but I prefer Olson's match baldes. They seem to last longer At $0.40 per blade that matters to me. IKE Edited February 4, 2018 by ike kmmcrafts and OCtoolguy 1 1 Quote
kmmcrafts Posted February 4, 2018 Report Posted February 4, 2018 If I were you, I'd buy their sample packs.. most of the blade manufactures offer packs of samples of different size blades.. When I was wanting to TRY the Pegas brand.. I ordered the ready made sample packs of each style blade style they offered except the spirals as I didn't even know they had spirals at the time.. from reverse tooth - the modified geometry ones.. This way I was able to try each blade style in several different sizes.. to see what works for me best.. It's a little bit of money up front doing this way.. but getting the best working blade for your type of scroll sawing will greatly improve your work and your fun of scroll sawing. I do this because the different styles and brands are that much different.. ie where I used to use a FD - UR #5 blade.. in the Pegas I can cut with the #3 MFGY blade.. Also when I drill the smaller holes for fine detail work.. the number 5 blade from Pegas won't fit in the hole as the #5 FD-UR will.. so the numbering system isn't really the same through all of the blade brands and styles.. #5 blade on 5/16 BB is pretty aggressive especially on the DeWalt and for someone just starting out.. bet you had a hard time in the tight turns with a blade like that one.. as you mentioned in my video how I do the tight corners with ease.. OCtoolguy 1 Quote
tomsteve Posted February 4, 2018 Report Posted February 4, 2018 12 hours ago, octoolguy said: Thanks. That's where I got them before Mike retired. But, I was just wondering if any of the other mfgrs. made anything similar. I have looked at all the blade charts for Olson, and Pegas but so far, I don't see anything like the FD-UR blades. Ray other manufacturers of blades do make reverse tooth blades, but i cant say how they compare to FD blades as FD are all ive used. i have read some about the blades that judy gale roberts is selling. it reads like they are a high quality blade and theres a couple different geometries to them https://intarsia.com/collections/scroll-saw-blades/products/gold-blades-dozen?variant=33146093830 OCtoolguy 1 Quote
OCtoolguy Posted February 4, 2018 Author Report Posted February 4, 2018 6 hours ago, kmmcrafts said: If I were you, I'd buy their sample packs.. most of the blade manufactures offer packs of samples of different size blades.. When I was wanting to TRY the Pegas brand.. I ordered the ready made sample packs of each style blade style they offered except the spirals as I didn't even know they had spirals at the time.. from reverse tooth - the modified geometry ones.. This way I was able to try each blade style in several different sizes.. to see what works for me best.. It's a little bit of money up front doing this way.. but getting the best working blade for your type of scroll sawing will greatly improve your work and your fun of scroll sawing. I do this because the different styles and brands are that much different.. ie where I used to use a FD - UR #5 blade.. in the Pegas I can cut with the #3 MFGY blade.. Also when I drill the smaller holes for fine detail work.. the number 5 blade from Pegas won't fit in the hole as the #5 FD-UR will.. so the numbering system isn't really the same through all of the blade brands and styles.. #5 blade on 5/16 BB is pretty aggressive especially on the DeWalt and for someone just starting out.. bet you had a hard time in the tight turns with a blade like that one.. as you mentioned in my video how I do the tight corners with ease.. Yes, you are so right. I had a tough time with the tight and circular turns. Many screwups. So, what you are saying is, I should be using a smaller blade like a FD-UR 3? I don't have that size. It didn't come in the sample pack. Everything is that pack is a #5. I asked this question because I want to order some more blades but before doing that, I wanted to find out if that same type blade was made by any of the other mfgrs. I will get hold of Mike's and order some smaller blades in the UR configuration. Thanks. Ray Quote
kmmcrafts Posted February 4, 2018 Report Posted February 4, 2018 (edited) 18 minutes ago, octoolguy said: Yes, you are so right. I had a tough time with the tight and circular turns. Many screwups. So, what you are saying is, I should be using a smaller blade like a FD-UR 3? I don't have that size. It didn't come in the sample pack. Everything is that pack is a #5. I asked this question because I want to order some more blades but before doing that, I wanted to find out if that same type blade was made by any of the other mfgrs. I will get hold of Mike's and order some smaller blades in the UR configuration. Thanks. Ray I haven't ordered FD blades in over a year.. but they used to have a sample pack of the FD-UR that came with 6? blades of each size of the UR blades.. Anyone know do they still offer these sample packs? You'd get a #1, #3 #5 #7 I believe it was 6 of those each size.. same with the other style blades they offer such as the SR ( Scroll Reverse ) and probably the spirals etc.. get the sample packs. not the dozen packs of each size..as that can get expensive.. When Mike was alive and running the business.. he'd send you a couple blades free of charge to try.. if he didn't have the sample packs or if you needed a specific blade to try.. that is how he became the king of blades and why FD blades got so popular.. Edited February 4, 2018 by kmmcrafts OCtoolguy 1 Quote
OCtoolguy Posted February 4, 2018 Author Report Posted February 4, 2018 44 minutes ago, kmmcrafts said: I haven't ordered FD blades in over a year.. but they used to have a sample pack of the FD-UR that came with 6? blades of each size of the UR blades.. Anyone know do they still offer these sample packs? You'd get a #1, #3 #5 #7 I believe it was 6 of those each size.. same with the other style blades they offer such as the SR ( Scroll Reverse ) and probably the spirals etc.. get the sample packs. not the dozen packs of each size..as that can get expensive.. When Mike was alive and running the business.. he'd send you a couple blades free of charge to try.. if he didn't have the sample packs or if you needed a specific blade to try.. that is how he became the king of blades and why FD blades got so popular.. Thanks Kevin. I'll check that out. When I bought the sample pack, it came with 5 different configurations and if I recall a dozen of each. That's how I ended up with the UR blades that I have. I like these because they have the reverse teeth the entire length of the blade. They don't seem to try to "lift" the wood off the table like the other reverse blades do. Ray kmmcrafts 1 Quote
amazingkevin Posted February 5, 2018 Report Posted February 5, 2018 6 hours ago, octoolguy said: Thanks Kevin. I'll check that out. When I bought the sample pack, it came with 5 different configurations and if I recall a dozen of each. That's how I ended up with the UR blades that I have. I like these because they have the reverse teeth the entire length of the blade. They don't seem to try to "lift" the wood off the table like the other reverse blades do. Ray 1 To each his own.I'll cut with what ever i have!!!!!!!!!!!!!!!!!!!!!!!!!! OCtoolguy 1 Quote
