rdatelle Posted February 8, 2018 Report Share Posted February 8, 2018 Hi everyone. I have a question for you all. I ordered some Ambrosia blocks which were 4 x 4 x 2. I want to make a few bird houses out of some of it. Well when I received it I noticed that it was all coated in wax which I never seen done before. Has anyone run into this problem and how did you get it off. I was able to run one block through my table saw and and shave a little off each side. All comments welcome. Quote Link to comment Share on other sites More sharing options...
Scrappile Posted February 8, 2018 Report Share Posted February 8, 2018 (edited) Actually I have found that common with blocks of wood like bowl blanks and such. I have several blanks that have been waxed. I think it is to help keep them from drying and cracking. Cutting/turning it off is what I have always done. I suppose a scrapper would get a lot of it. Edited February 8, 2018 by Scrappile tomsteve 1 Quote Link to comment Share on other sites More sharing options...
Travis Posted February 8, 2018 Report Share Posted February 8, 2018 The wax is to stabilize the moisture in the block. Quick changes in humidity will crack the wood, especially if it's being transported from other countries. Its pretty common practice with turning blanks. 4x4x2 sounds like a bowl blank size. With woodturning, that would get cut away during shaping. Not sure about with scroll sawing. I'd try scraping it with a putty knife then sanding. See if that helps. Maybe heat gun and paper towels. But I'd be afraid the wax would seep into the pours. tomsteve and OCtoolguy 1 1 Quote Link to comment Share on other sites More sharing options...
rdatelle Posted February 8, 2018 Author Report Share Posted February 8, 2018 I was able to cut three pieces out of the one block which are 1 - 1/4 x 1 - 1/4. I made 3 bird houses out of the one block and 6 birds. tomsteve and new2woodwrk 2 Quote Link to comment Share on other sites More sharing options...
Dan Posted February 8, 2018 Report Share Posted February 8, 2018 Like the others have it keeps the wood stabile. I use the bandsaw to remove the wax. OK Ralph, show the pictures. Quote Link to comment Share on other sites More sharing options...
oldhudson Posted February 8, 2018 Report Share Posted February 8, 2018 Denatured alcohol should take the wax right off. new2woodwrk 1 Quote Link to comment Share on other sites More sharing options...
new2woodwrk Posted February 8, 2018 Report Share Posted February 8, 2018 3 hours ago, rdatelle said: I was able to cut three pieces out of the one block which are 1 - 1/4 x 1 - 1/4. I made 3 bird houses out of the one block and 6 birds. Where's the pics - we want piCs ! Quote Link to comment Share on other sites More sharing options...
rdatelle Posted February 9, 2018 Author Report Share Posted February 9, 2018 I just put the finish on today. I'll have pics tomorrow. Dan, I knew you would know. I liked the ones you did. With that wood. I'll try the band saw on the next one. Quote Link to comment Share on other sites More sharing options...
dgman Posted February 9, 2018 Report Share Posted February 9, 2018 A word of caution. As has been stated, the wax is applied to wet wood to slow down drying so the wood does not check or split. What this means is the wood may not be as dry as kiln dried wood would be. As wood dries, it may develop checks and may distort. Hopefully, this won't happen if the wood was dry enough. tomsteve 1 Quote Link to comment Share on other sites More sharing options...
Dan Posted February 9, 2018 Report Share Posted February 9, 2018 Good point Dan. When I cut blanks for pen in wood with a moisture content of 20% or higher I seal the ends with latex paint and put them in the dehydrator for about 8 hours. The wood is thin enough to get the moisture our with little if any twisting and no cracks. I never thought about this for larger blanks. BTW, I have a separate dehydrator I use for my beef jerky. tomsteve 1 Quote Link to comment Share on other sites More sharing options...
amazingkevin Posted February 9, 2018 Report Share Posted February 9, 2018 7 hours ago, rdatelle said: Hi everyone. I have a question for you all. I ordered some Ambrosia blocks which were 4 x 4 x 2. I want to make a few bird houses out of some of it. Well when I received it I noticed that it was all coated in wax which I never seen done before. Has anyone run into this problem and how did you get it off. I was able to run one block through my table saw and and shave a little off each side. All comments welcome. Wish I had some scraps! Quote Link to comment Share on other sites More sharing options...
rdatelle Posted February 9, 2018 Author Report Share Posted February 9, 2018 (edited) Thanks for all the tips. The wood looks pretty dry once I cut the wax off. Edited February 9, 2018 by rdatelle Quote Link to comment Share on other sites More sharing options...
Lucky2 Posted February 9, 2018 Report Share Posted February 9, 2018 Ralph, you bought turning stock, the best way to remove the wax is with the table saw. Well maybe not the best way, but it's the way I prefer. And as mentioned above, the wood isn't dry. Len Quote Link to comment Share on other sites More sharing options...
rdatelle Posted February 9, 2018 Author Report Share Posted February 9, 2018 (edited) Thanks Len. That's how I did it to. Was a little messy. Once I got the wax off, the wood looked dry. Edited February 9, 2018 by rdatelle Quote Link to comment Share on other sites More sharing options...
