Vector01 Posted February 9, 2018 Report Posted February 9, 2018 Well finally got down to trying out my new Jet SS. All in all worked great. Only drawback had to use cheap ply from Lowes. Had a few breaks and chips along the way. Patter from Steve Good. Sam777, Dan, Lucky2 and 6 others 9 Quote
DWSUDEKUM Posted February 9, 2018 Report Posted February 9, 2018 Very nicely done. I like that pattern. Thanks for sharing this with us. DW Quote
lawson56 Posted February 9, 2018 Report Posted February 9, 2018 Alwyas Loved that pattern.You done it Proud. Quote
new2woodwrk Posted February 9, 2018 Report Posted February 9, 2018 That's a nice looking eagle! Thanks for sharing Quote
Scrappile Posted February 9, 2018 Report Posted February 9, 2018 Nice job. Looks like that saw works well for you. Quote
heppnerguy Posted February 9, 2018 Report Posted February 9, 2018 That is a great pattern.. I to have looked at it but never felt an urge to cut it. You may have changed my mind. Nicely done. Dick heppnerguy Quote
amazingkevin Posted February 10, 2018 Report Posted February 10, 2018 18 hours ago, Vector01 said: Well finally got down to trying out my new Jet SS. All in all worked great. Only drawback had to use cheap ply from Lowes. Had a few breaks and chips along the way. Patter from Steve Good. You've polished your cutting skills immensely!!!!!!!!!!!!! Quote
wombatie Posted February 10, 2018 Report Posted February 10, 2018 Very nice. Well done Vector. Marg Quote
Dave Monk Posted February 11, 2018 Report Posted February 11, 2018 Great job with that new Jet. Quote
bobscroll Posted February 11, 2018 Report Posted February 11, 2018 You did very well on the Eagle project, Thanks for letting us see, Bob Quote
Lucky2 Posted February 14, 2018 Report Posted February 14, 2018 Nicely done, how was the new Jet to use, was it any different then any other scroll saw? Len Quote
Vector01 Posted February 15, 2018 Author Report Posted February 15, 2018 On 2/14/2018 at 5:11 AM, Lucky2 said: Nicely done, how was the new Jet to use, was it any different then any other scroll saw? Len The jet was fantastic. Due to the lack of noticeable vibration, the small detail cuts were easy. I would compare it to my old Dewalt(Canada mfg.), as far as power and ease of cutting all types of wood. The jet has more adjustments for fine tuning (blade tension and movement) than the Dewalt. The plus with the jet is the ease of blade changes and the top arm adjustment which allows the arm to stay up when doing inside cuts. It works a lot better than my old Porter Cable saw. My Porter Cable worked fine until the vibration issue became a problem. The PC was over 4 years old, not worth fixing. Bar any problems, this will be my last saw! Here's a couple more I did... bobscroll and Lucky2 2 Quote
bobscroll Posted February 15, 2018 Report Posted February 15, 2018 Two more to look at, And they look real nice! I like the tree of life you did, Thank you for posting, Bob Quote
Rockytime Posted February 15, 2018 Report Posted February 15, 2018 You're doing some nice work on that Jet. Quote
Lucky2 Posted February 16, 2018 Report Posted February 16, 2018 Art, these last two projects are very nice looking also, how was the jet to use for inlay work? Have you ever tried using an EX21 scroll saw, they're a lot like the jet? Len Quote
Vector01 Posted February 19, 2018 Author Report Posted February 19, 2018 Hi Lucky2: Never used the Ex21. But appears to be the same as Jet. My understanding is the Jet is the new EX21? The inlay worked fine. Could have used a smaller blade to reduce the kerf on the cheese board. I usually use the Olson 5R blade for most of my projects. Quote
heppnerguy Posted February 19, 2018 Report Posted February 19, 2018 Both projects came out really well. I am using my new EX and loving it also. So glad I found one for sale and it was brand new for $200. The only thing I would change if I were doing these two project is, I believe a black backer board would have made the tree of live stand out better. Good work on it Dick heppnerguy Quote
